[snappyHexMesh] HOW to set a circular face by toposet
Old   September 7, 2013, 05:26
Question HOW to set a circular face by toposet
Jessica
Jessica is on a distinguished road
Hello,everyone
There is a simple blockmesh, it is easy to set a square face on the boundray by topoSet using 'boxtoface' as follows.
BLOCKMESH:
vertices
    (-0.5 -0.5 0)
    ( 0.5 -0.5 0)
    ( 0.5 -0.5 1)
    (-0.5 -0.5 1)
    (-0.5  0.5 0)
    ( 0.5  0.5 0)
    ( 0.5  0.5 1)
    (-0.5  0.5 1)
blocks
    hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1)
edges
boundary
    base
        type patch;
        faces
            (0 1 5 4)
    outlet
        type patch;
        faces
            (3 2 6 7)
    sides
        type patch;
        faces
            (0 4 7 3)
            (0 1 2 3)
            (1 5 6 2)
            (4 5 6 7)
TOPOSET:
actions
        name    f0;
        type    faceSet;
        action  new;
        source  boxToFace;
        sourceInfo
            box (-0.1 -0.001 -0.1)(0.1 0.005 0.1);
But I don't know how to set a circular face using the toposet, and I am puzzled after 'cylinderToCell' , please help me!
TOPOSET
        name    c0;
        type    cellSet;
        action  new;
        source  cylinderToCell;
        sourceInfo
         p1       (0 0 -0.001); // start point on cylinder axis
         p2       (0 0 0.025);   // end point on cylinder axis
         radius   0.2;
Thanks in advance!!!
Jessica is offline   Reply With Quote
Old   September 11, 2013, 05:33
Artur's Avatar
Artur
Artur will become famous soon enough
As far as I know, cylinderToCell will select all cells inside the cylinder with the two circle centres at p1 and p2 with radius r, that's about it. If your mesh is a box then it will not turn it into a cylindrical mesh, I think.
The way I use it to create AMI interfaces is by snapping the mesh to a cylindrical shape and then using the cylinderToCell to select the snapped cells, much as in the propeller tutorial.
Artur is offline   Reply With Quote
Old   September 12, 2013, 20:54
Jessica
Hi,Autur,
Thank you for you reply. I'm trying.
toposet circular
[ICEM] Error in mesh writing helios ANSYS Meshing & Geometry 21 August 19, 2021 14:18
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 18:57
[blockMesh] non-orthogonal faces and incorrect orientation? nennbs OpenFOAM Meshing & Mesh Conversion 7 April 17, 2013 05:42
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
