November 25, 2013, 03:00 |
surface is not closed.
Dongyue Li
Hi guys,
I generate a cylinder using ICEM, but OpenFOAM says its not closed. How can I modify this? Thanks. Code:
// * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Reading surface from "outerCylinder.stl" ... Statistics: Triangles : 8332 Vertices : 4232 Bounding Box : (-0.238 -0.11424 -0.238) (0.238 1 0.238) Region Size ------ ---- GEOM 8332 Surface has no illegal triangles. Triangle quality (equilateral=1, collapsed=0): 0 .. 0.05 : 0.018483 0.05 .. 0.1 : 0.0820931 0.1 .. 0.15 : 0.0808929 0.15 .. 0.2 : 0.0525684 0.2 .. 0.25 : 0.0468075 0.25 .. 0.3 : 0.0480077 0.3 .. 0.35 : 0.0405665 0.35 .. 0.4 : 0.0400864 0.4 .. 0.45 : 0.043687 0.45 .. 0.5 : 0.0463274 0.5 .. 0.55 : 0.0511282 0.55 .. 0.6 : 0.0648104 0.6 .. 0.65 : 0.081133 0.65 .. 0.7 : 0.0679309 0.7 .. 0.75 : 0.0588094 0.75 .. 0.8 : 0.0552088 0.8 .. 0.85 : 0.0542487 0.85 .. 0.9 : 0.0554489 0.9 .. 0.95 : 0.0110418 0.95 .. 1 : 0.000720115 min 0.0285532 for triangle 2306 max 0.975663 for triangle 613 Edges: min 0.00022722 for edge 1 points (0.01061 -0 -0.237763)(0.0106 -0.000227 -0.237763) max 0.400756 for edge 10958 points (-0.168291 0.3 0.168291)(-0.150011 0.7 0.184772) Checking for points less than 1e-6 of bounding box ((0.476 1.11424 0.476) meter) apart. Found 0 nearby points. Surface is not closed since not all edges connected to two faces: connected to one face : 384 connected to >2 faces : 0 Conflicting face labels:384 Dumping conflicting face labels to "problemFaces" Paste this into the input for surfaceSubset Number of unconnected parts : 3 Splitting surface into parts ... writing part 0 size 7308 to "outerCylinder_0.obj" writing part 1 size 384 to "outerCylinder_1.obj" writing part 2 size 640 to "outerCylinder_2.obj" |
SampledSurface, can't find closed walk around surface | nikwin | OpenFOAM | 4 | September 23, 2020 09:46 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 11:05 |
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry | pizzaspinate | OpenFOAM Meshing & Mesh Conversion | 1 | February 25, 2015 07:05 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 04:31 |
[Gmsh] boundaries with gmshToFoam | ouafa | OpenFOAM Meshing & Mesh Conversion | 7 | May 21, 2010 12:43 |
