[snappyHexMesh] Free edges - extraction
Old   January 15, 2014, 09:12
Default Free edges - extraction
Aurelien Thinat
Aurelien Thinat is on a distinguished road
Hello everyone,
I have a cylinder, a baffle surface, which I import in snappyHexMesh as a .stl file. This cylinder is immerged in a box (stl file too).
Everything is going well with snappy except one thing : the cylinder presents few holes, each hole delimited by a "free edge". When I'm using the surfaceFeatureExtract tool, I'm not able to extract only these free edges in the eMesh file.
But when I activate the option "export obj files", there is one file with these edges only.
So my question is : is there any way to extract only the free edges ? By converting the obj file into eMesh maybe ?
Thank you.
NB : I'm using OpenFOAM-2.2.2.
Aurelien Thinat is offline   Reply With Quote
Old   January 15, 2014, 11:35
Aurelien Thinat
Well, if anyone is wondering the same thing, one can follow this :
1) enable the writing of obj files
2) call the surfaceFeatureExtractDict
3) launch this command :
surfaceFeatureConvert ./extendedFeatureEdgeMesh/mySTL_externalEdges.obj ./triSurface/myFile.eMesh
It will replace the "all-edges.eMesh" file by a "external-only-edges.eMesh" file. It does the job perfectly.
[ICEM] Locked node numbers on edges are changed by ICEM bl!nk ANSYS Meshing & Geometry 3 February 3, 2018 07:32
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 03:21
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[ICEM] mesh is not aligned with edges OliverL ANSYS Meshing & Geometry 0 November 7, 2011 07:59
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
