[snappyHexMesh] snappyHexMesh stops meshing
Old   January 24, 2014, 06:45
Wink snappyHexMesh stops meshing
James
Tensian is on a distinguished road
Hi Foamers,
I am trying to simulate flow across a channel with two inlets, an outlet and a wall. The model have to take in count heat transfer. I have four separated stl files (one for each boundary) and I am meshing it with OF native meshers.
I am having some problerms with snappyHexMesh. It looks a good choice for meshing but it's quite difficult to understand what this mesh generator is doing and how to set all parameters in order to obtain an optimal mesh.
When I use snappy, sometiemes I am getting errors that I cannot understand. Basically, I have three situations:
1. snappy stops meshing without no information in the log file. I attach some cases at the end of the post.
2. snappy gives an error message when creating layers in step three.
3. snappy shows a message about memorym usage.
I am running about three or four executions of snappy simoultaneously. Could this be the source of the errors?I think the CPU have enough power and memory for do that, but I am not really sure...
Also I am having problems with the use of surfaceFeatureExtract. The surface is better represented, but the mesh doesn't pass checkMesh test (skewness mainly). Have I to use this tool for all my stl files or for example is enough to use it for wall.stl?
And with layers creation, I have never achieved a good visualization of layers, because they are always collapsed in some sharp places andf sometimes they are simply not created. Does somebody have any hint about that issue?
Thanks in advance for all the help provided!If more files are needed I can provide it...
Tensian is offline   Reply With Quote
Old   January 25, 2014, 05:23
Julian Langowski
Ruli is on a distinguished road
Hi Tensian,
I will test it when I have got time.
How does it look like?
How many cells does the mesh contain? Snappy is very RAM-intensive, especially in the layer addition phase. I would say you need 2-3 times the number of cells in GB RAM.
Bye
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
Old   January 26, 2014, 09:54
Smile
James
Hi Ruli and thanks for your interest,
The layer mesh is not being created. You can see all the information in log_stopped_layercreation (attached in previous post).
Anyway, I attach a new case with problems in layer creation (snappyDict, log file and a image with layers collapse). This time the layers are created, but they collapse in an unknown way. Maybe somebody could give me any hint on this. I am using surfaceFeatureExtract for preserve the feature edges of my geometry.
The number of elements of the final mesh is around 3-4 million cells. I will work carefully then due to memory requirements of snappy. By the way I have 32 Gb RAM and 8 procerssors, so it will be enough!
Thanks, I am impatient with finding the solution of the problem!
[snappyHexMesh] snappyHexMesh issue on parallel meshing makaveli_lcf OpenFOAM Meshing & Mesh Conversion 1 February 20, 2018 17:27
[snappyHexMesh] meshing gerotor and Snappyhexmesh thomsi OpenFOAM Meshing & Mesh Conversion 0 October 17, 2016 10:35
[snappyHexMesh] Meshing Naca0012 with snappyHexMesh kasimirXV OpenFOAM Meshing & Mesh Conversion 10 May 10, 2016 23:04
[snappyHexMesh] Problem Meshing a V-notch Weir with snappyHexMesh kflora OpenFOAM Meshing & Mesh Conversion 11 December 19, 2011 01:58
[snappyHexMesh] Meshing a sphere with snappyHexMesh Cyberholmes OpenFOAM Meshing & Mesh Conversion 2 July 19, 2011 16:46
