[snappyHexMesh] SHM RAM and -parallel proplem
Like Tree1Likes
  • 1 Post By student666
Old   May 16, 2014, 11:50
Default SHM RAM and -parallel proplem
Heremus is on a distinguished road
I'm relative new to openFOAM but I managed to get a working snappyHexMeshDict and now I'm trying to get a better resolution at my geometry. So that the round parts are more segmented in the final net. (It's a round air-foil, shaped like a ring). With the previous refinement levels it wasn't enough refined. So now I have 2 problems.
First of all I have an RAM/Swap Issue. I put the refinement level to 8 which actually worked. Then I put it up to 9 and the increased need of memory crashed the PC's. (5, 8 and 16 GB RAM + 4 GB Swap). I played with various parameters but hadn't any success to get very clean shape of my geometry.
Any suggestions how I can trim my snappyHexMeshDict file?
FoamFile
        version 2.0;
        format ascii;
        root "";
        case "";
        instance "";
        local "";
        class dictionary;
        object autoHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
addLayers       true;
geometry
    hull.stl
        type triSurfaceMesh;
        name DIFUSOR;
        regions
            OBJECT
                name difusorHull;
    refinementBox
        type searchableBox;
        min (-0.50 -1.25 0);
        max (2 1.25 2.8);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    maxLocalCells 10000000;                //Max cells pro CPU
    maxGlobalCells 10000000;            //Max overall cells
    minRefinementCells 50;                //Loopbreaker if the to refine cells are less than this Number
    nCellsBetweenLevels 1;                //Defines the refinement of one level
    features
    ({file "hull.eMesh"; level 0;});
    refinementSurfaces
        DIFUSOR
            level (6 9);
    resolveFeatureAngle 30;            //Refinement if some FeatureAngle is higher than this
    refinementRegions
        refinementBox
            mode inside;
            levels ((0.1 3));
        DIFUSOR
            mode distance;
            levels ((0.02 9) (0.6 8) (0.2 7));
    locationInMesh (8 8 0.5);            //Snappy meshing inside or outside a model
    allowFreeStandingZoneFaces false;
// Settings for the snapping.
snapControls
    nSmoothPatch    8;         // presmoothing iterations before correspondence is set
    tolerance       1.0;        // relative distance the program searches for snappoints
    nSolveIter      80;        // how often do snapiterations bigger-->better-->longer
    nRelaxIter      5;        // remove bad meshpoints. Should end before reaching value
    implicitFeatureSnap false;     // using surfaceFeatureExtract Method(generates eMesh)
// Settings for the layer addition.
addLayersControls
    layers
        difusorHull
            nSurfaceLayers 6;
    relativeSizes true;
    expansionRatio 1.15;
    finalLayerThickness 0.2;
    minThickness 0.1;
    nGrow 1;
// Advanced Setting
    featureAngle 30;
    nRelaxIter 5;
    nSmoothSurfaceNormals 1;
    nSmoothNormals 3;
    nSmoothThickness 10;
    maxFaceThicknessRatio 0.5;
    maxThicknessToMedialRatio 0.3;
    minMedianAxisAngle 80;
    nBufferCellsNoExtrude 0;
    nLayerIter 50;
    nRelaxedIter 20;
meshQualityControls
    maxNonOrtho 65;
    maxBoundarySkewness 20;
    maxInternalSkewness 4;
    maxConcave 80;
    minVol 1e-13;
    minTetQuality 1e-9;
    minFlatness 0.5;
    minArea -1;
    minTwist 0.05;
    minDeterminant 0.001;
    minFaceWeight 0.05;
    minVolRatio 0.01;
    minTriangleTwist -1;
    nSmoothScale 4;
    errorReduction 0.75;
    relaxed
// Advanced
// Flags for optional output
debug 0;
mergeTolerance 1e-6;
Secondly I have a the option to use a preconfigured cluster. This would help me also with my memory-issue because I can split it up between different PC's. But I think I make some mistakes. When I use the command:
mpirun --hostfile system/machines -np 4 snappyHexMesh -parallel > meshLog
it produces this error:
[NameOfServer:22784] Error: unknown option "--daemonize"
I tried to run it with --no-daemonize option but that had no effect.
I also checked if I can access to every server without verification and that worked. May I initialise OpenFOAM incorrectly or I use the mpirun wrong?
Heremus is offline   Reply With Quote
Old   June 11, 2014, 07:52
Default ram
Calum Douglas
snowygrouch is on a distinguished road
well firstly if you want very high refinement, but dont have enough RAM - you cant do it. You`ll have to just use lower refinement levels.
However you have set you max cell count as identical for both
CPU and entire case. Which isnt very good as the CPU
will run out of cells and stop refinement before anything else happens.
As a rough guide you should divide total system ram by # cores and use that as a ratio.
Ie. if you have 16gb RAM with 8 cores, you have 2gb per core.
Hence your max cell count total should be 8x higher than the max cell count per cpu.
Right now you have 10 million cells as max for BOTH each core AND the total solution.
I have no idea how much total ram you have but, I would change it for example to something like this (if you have 4 cores for example)
maxLocalCells 4000000;
maxGlobalCells 16000000;
Calum Douglas
Director
Scorpion Dynamics Ltd
Email: calum.douglas@scorpion-dynamics.com
Web: www.scorpion-dynamics.com
snowygrouch is offline   Reply With Quote
Old   June 26, 2014, 11:10
Cool thank you for your help!
I tried your settings but unfortunately it requires so much more space than before that it nearly crashed instantly. And I have 4 cores and 16 Gb of RAM
I will try if there is an 0 to much in the maxLocalCells but then it's 40x.
Old   June 26, 2014, 13:10
Default refinement
Calum Douglas
Your refinement levels are incredibly high.
If you`ve only got 16gb ram, and the model is large - you
will have to lower those or you`ll never mesh it.
If you want to do more, you`ll have to buy more ram. I`ve got 32GB
and wish I had twice that....
you`ll just have to try something like
levels ((0.02 4) (0.6 3) (0.2 2))
and work upwards until you reach the limit of your machine.
Calum Douglas
Director
Old   July 7, 2014, 07:05
M. C.
student666 is on a distinguished road
Hi all,
is there a reference table, or a "not-written" rule, that can help to estimate how many cells should be allocated for each core and for total amount of RAM?
enginpower likes this.
student666 is offline   Reply With Quote
mpirun, openfoam, parallel computation, snappyhexmesh
Huge increase of RAM makes parallel mpirun fails choch OpenFOAM 2 November 12, 2018 10:42
[snappyHexMesh] Snappyhexmesh parallel using all RAM snowygrouch OpenFOAM Meshing & Mesh Conversion 2 May 29, 2014 16:57
ECC vs. non ECC ram: My opinion ghost82 Hardware 19 February 13, 2014 09:32
New workstation for different usage scenarios - CPU and RAM natem Hardware 6 August 7, 2013 02:47
Messhing in Parallel: CPU <5% Ram > 90% Allrun Sleeping stark22 OpenFOAM Running, Solving & CFD 0 December 2, 2012 10:28
