[snappyHexMesh] How to define the computational region with snappyHexMeshDict |
June 11, 2014, 19:20 |
xurenyi
Rep Power: 12 |
in
\tutorials\incompressible\simpleFoam\turbineSiting a surface(.STL file) cut the background region( a cube) to 2 parts. How to select one of the parts with setting parameters in snappyHexMeshDict? As the same \tutorials\multiphase\interPhaseChangeFoam\cavitat ingBullet If I want to compute the interior region of the bullet (assuming the bullet is empty inside), how to set parameters in snappyHexMeshDict? |
June 12, 2014, 04:19 |
Eloïse
Rep Power: 13 |
The snappyHexMeshDict parameter locationInMesh defines which part is selected for meshing. Regards, Eloïse |
June 12, 2014, 09:11 |
xurenyi
Rep Power: 12 |
June 12, 2014, 09:20 |
Eloïse
Rep Power: 13 |
It is just a coincidence. You can have as many refinement regions as you want, or none.
Regards, Eloïse |
Hydrogen storage by metal hydride | longbk | FLUENT | 12 | August 1, 2023 20:13 |
p_rgh initial residual no change with different settings | manuc | OpenFOAM Running, Solving & CFD | 3 | June 26, 2018 15:53 |
How to define the depth of computional region in a pesudo-3D simulation? | Narita | FLUENT | 2 | May 28, 2016 09:09 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 13:12 |
UDF carbon conversion | papteo | Fluent UDF and Scheme Programming | 1 | August 18, 2011 07:32 |
