[snappyHexMesh] SnappyHexMesh Problem
Like Tree1Likes
  • 1 Post By snak
Old   July 8, 2014, 15:20
Default SnappyHexMesh Problem
Muhammad Waqas
mwaqas is on a distinguished road
Send a message via Skype™ to mwaqas
Hello everyone
I am quite new with OpenFoam and I am trying to mesh a cylinder with SnappyHexMesh from inside. I have created an stl file for cylinder in Paraview, then i did changes in snappyHexmeshdict accordingly. I used blockmesh (a cube) to enclose that cylinder.
After that i tried to mesh cylinder but in the end I got only that meshed cube. there was no cylinder.
Can you please tell me what could be the possible problems.
And how can I use snappyhexmesh for cylinder in detail including commands which i have to write in terminal (stepwise).
Thank you
mwaqas is offline   Reply With Quote
Old   July 9, 2014, 05:18
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
it'll be easier to get an answer to the question if
- you just post case files
- (if previous is not possible) post pictures of the cylinder, what you'd like to get from sHM, what you get from sHM.
(also if it's just a cylinder, in fact, there's no point in using sHM)
alexeym is offline   Reply With Quote
Old   July 9, 2014, 05:46
Muhammad Waqas
| \\ / O peration | Version: 2.2.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object snappyHexMeshDict;
castellatedMesh true;
snap true;
addLayers false;
geometry // Load in STL files here
cylinder.stl {type triSurfaceMesh; name cylinder;}
//refinementBox {type searchableBox; min (-0.1 -0.1 -0.05); max ( 0.1 0.1 0.05);}
castellatedMeshControls
maxLocalCells 1000000; //max cells per CPU core
maxGlobalCells 2000000; //max cells to use before mesh deletion step
minRefinementCells 10; //was 0 - zero means no bad cells are allowed during refinement stages
maxLoadUnbalance 0.10;
nCellsBetweenLevels 1; // expansion factor between each high & low refinement zone
// Explicit feature edge refinement
features // taken from STL from each .eMesh file created by "SurfaceFeatureExtract" command
{file "cylinder.eMesh"; level 3;}
// Surface based refinement
refinementSurfaces // Surface-wise min and max refinement level
cylinder {level (3 3);}// was 0 0
resolveFeatureAngle 80; // Resolve sharp angles // Default 30
refinementRegions // In descending levels of fine-ness
{flange {mode distance; levels ((0.0006 4) (0.002 3) (0.01 2));}} // was ((0.001 4) (0.003 3) (0.01 2))
locationInMesh (0.01 0.01 0.01); //to decide which side of mesh to keep **
allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
nSmoothPatch 3;
tolerance 4.0;
nSolveIter 30;
nRelaxIter 5;
nFeatureSnapIter 15; // default is 10
// New settings from openfoam 2.2 onwards for SHMesh
implicitFeatureSnap false; // default is false - detects without doing surfaceFeatureExtract
explicitFeatureSnap true; // default is true
multiRegionFeatureSnap false; // deafault is false - detects features between multiple surfaces
// Settings for the layer addition.
addLayersControls //add the PATCH names from inside the STL file so STLpatchName_insideSTLName
relativeSizes true;//false; // was true
layers
//visc_main
cylinder
{nSurfaceLayers 3;} // was 3
expansionRatio 1.3;
finalLayerThickness 0.00016; //was 0.00016
minThickness 0.00008; //was 0.00008
nGrow 0; // was 1
// Advanced settings
featureAngle 80; // was 70 //- When not to extrude surface. 0 is flat, 90 is right angle.
nRelaxIter 3; //- Max# of snapping relaxation iter. Should stop before upon reaching a correct mesh.
nSmoothSurfaceNormals 1; // Number of smoothing iterations of surface normals
nSmoothNormals 3; // Number of smoothing iterations of interior mesh movement direction
nSmoothThickness 10; // Smooth layer thickness over surface patches
maxFaceThicknessRatio 0.5; // Stop layer growth on highly warped cells
maxThicknessToMedialRatio 0.3; // Reduce layer growth where ratio thickness to medial distance is large
minMedianAxisAngle 130; // Angle used to pick up medial axis points
nBufferCellsNoExtrude 0; // Create buffer region for new layer terminations
nLayerIter 50; // Overall max number of layer addition iterations
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
maxNonOrtho 65;
maxBoundarySkewness 20;
maxInternalSkewness 4;
maxConcave 80;
minFlatness 0.5;
minVol 1e-13;
minTetQuality 1e-9;
minArea -1;
minTwist 0.02;
minDeterminant 0.001;
minFaceWeight 0.02;
minVolRatio 0.01;
minTriangleTwist -1;
// Advanced
nSmoothScale 4;
errorReduction 0.75;
// Advanced
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1E-6;
Old   July 9, 2014, 23:03
Thumbs up
shinji nakagawa
snak is on a distinguished road
Can you verify that cylinder.stl from PARAVIEW is OK?
STL files exported from paraview might not closed.
You can open the exported STL files to see how it looks like.
I think it is better to use other software to create STL files.
You can create basic shapes using snappyHexMesh itself.
Just adding the following lines inside the geometry section of snappyHexMeshDict.
cylinder
type searchableCylinder;
point1 (0 0 0); // center of bottom circle
point2 (2 0 0); // center of top circle
radius 2.5; // radius
snappyWiki is a good starting point.
https://sites.google.com/site/snappywiki/
Originally Posted by mwaqas View Post
Hello everyone
Thank you
mwaqas likes this.
snak is offline   Reply With Quote
Old   July 10, 2014, 06:51
Muhammad Waqas
thank you very much. I have checked my geometry it was not closed. Can you please tell me
1) If I use searchable cylinder in snappyHexMesh, then do I need any stl file in trisurface folder or shall I leave that folder empty. Also can I add patches if I use it
2) What other open source can I use to create stl file for simple geometry in which I could add patches e.g for inlet and outlet
Originally Posted by snak View Post
cylinder
Old   March 4, 2015, 05:57
Daniel Duque
dduque is on a distinguished road
Did you get an answer to your questions? I have run into the same difficulties. The searchableCylinder idea works fine, but the snappy complains about the features entry. With a valid stl, the file in this entry can be built with the surfaceFeatureExtract utility (not longer runs at command line, I enclose its dictionary below).
But, of course one does NOT have an stl if the cylinder is defined within searchableCylinder.
What I've ended up doing is saving a crappy, open cylinder with paraview, running surfaceFeatureExtract on it, putting the resulting cyl.eMesh where it should be, constant/triSurfaces, and then not using that at all, by adding these lines in my snappy dict:
features
file "cyl.eMesh";
levels ((0.01 0));
Not very elegant, but in my case the "cylinder" is just a simulation box, and I'm nor really worried about the edges.
About freeware alternatives, there's blender, but that's quite a complicated piece of software.
| \\ / O peration | Version: 2.3.1 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object surfaceFeatureExtractDict;
cyl.stl
// How to obtain raw features (extractFromFile || extractFromSurface)
extractionMethod extractFromSurface;
extractFromSurfaceCoeffs
// Mark edges whose adjacent surface normals are at an angle less
// than includedAngle as features
// - 0 : selects no edges
// - 180: selects all edges
includedAngle 150;
// Write options
// Write features to obj format for postprocessing
writeObj yes;
dduque is offline   Reply With Quote
Old   March 4, 2015, 14:53
Muhammad Waqas
Hello dduque
I got the answer of question.
I didn't understand your question. Will you please little bit elaborate your question.
Thank you
Old   April 28, 2015, 05:43
Sachin
Sachin m is on a distinguished road
Hi Foamers,
Iam Getting an error while trying to mesh a model using Snappy Hexmesh. Can anyone help me out with what this error is??
ERROR: In /home/openfoam/OpenFOAM/ParaView-4.1.0/VTK/IO/Geometry/vtkSTLReader.cxx, line 435
vtkSTLReader (0x739fa90): STLReader error reading file: /home/sachin/OpenFOAM/sachin-2.3.1/run/20pax/skeg/constant/triSurface/wigley-scaled-oriented.stl Premature EOF while reading solid.
Sachin m is offline   Reply With Quote
Old   April 28, 2015, 05:49
Muhammad Waqas
Hello
There is a problem with your STL file, can you please attach your STL file here
Regards
Old   April 28, 2015, 08:25
DanielP
danielpiaget is on a distinguished road
If you give my your email, i'll send you my complete cylinder case.
Thanks,
Daniel
danielpiaget is offline   Reply With Quote
Old   April 28, 2015, 17:04
Muhammad Waqas
waqas_chem133@yahoo.com
Regards
Old   May 7, 2015, 00:29
Sachin
Hi all,
Iam recieveing an error message when iam trying to mesh my geometry...what could be the possible issue??
*** Error in `snappyHexMesh': corrupted double-linked list: 0x000000002a34f710 ***
Thanks in advance
Old   May 7, 2015, 02:01
Sachin
Another error message is :
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigSegv::sigHandler(int) at ??:?
#2 in "/lib/x86_64-linux-gnu/libc.so.6"
#3 cfree in "/lib/x86_64-linux-gnu/libc.so.6"
Old   May 7, 2015, 02:02
Sachin
#4 Foam::List<int>:: operator=(Foam:: List<int> const&) at ??:?
#5 Foam::List<Foam:: face>:: List(Foam:: List<Foam:: face> const&) at ??:?
#6 Foam:: polyTopoChange::reorderCompactFaces(int, Foam:: List<int> const&) at ??:?
#7 Foam:: polyTopoChange::compact(bool, bool, int&, Foam::List<int>&, Foam::List<int>&) at ??:?
#8 Foam:: polyTopoChange::compactAndReorder(Foam:olyMesh const&, bool, bool, bool, int&, Foam::Field<Foam::Vector<double> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:: objectMap>&, Foam::List<Foam:bjectMap>&, Foam::List<Foam:: Map<int> >&, Foam::List<int>&, Foam::List<int>&, Foam::List<Foam::Map<int> >&) at ??:?
#9 Foam:olyTopoChange::changeMesh(Foam:olyMesh&, bool, bool, bool, bool) at ??:?
#10 Foam::meshRefinement::refine(Foam::List<int> const&) at ??:?
#11 Foam::meshRefinement::balanceAndRefine(Foam::strin g const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&, Foam::List<int> const&, double) at ??:?
#12 Foam::autoRefineDriver::surfaceOnlyRefine(Foam::re finementParameters const&, int) at ??:?
#13 Foam::autoRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, Foam::dictionary const&) at ??:?
#14
at ??:?
#15 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#16
at ??:?
Segmentation fault (core dumped)
[snappyHexMesh] Problem with decomposePar, snappyHexMesh luca1992 OpenFOAM Meshing & Mesh Conversion 12 August 23, 2017 19:06
[snappyHexMesh] snappyHexMesh problem cfdsolver1 OpenFOAM Meshing & Mesh Conversion 0 June 23, 2016 10:09
[snappyHexMesh] Problem handling with subdictionary in SnappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 0 November 21, 2015 13:57
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 14:46
[snappyHexMesh] Problem with snappyHexMesh giack OpenFOAM Meshing & Mesh Conversion 2 September 18, 2014 10:03
