[snappyHexMesh] snapping doesn't work properly
Old   January 8, 2015, 02:22
Default snapping doesn't work properly
Eugen
estang is on a distinguished road
I want to mesh a pipe and a fluid for conjugated heat transfer just to test the solver and learning how to use it. But my result is not snapped to the stl. I already played with the settings, i increased iterations in the snapControls and refined the mesh at the surface in castellatedMeshControls.
The images illustrate the fluiddomain and the soliddomain.
castellatedMesh   true;
snap              true;
addLayers         false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    FluidDomain.stl
        type triSurfaceMesh;
        name fluid;
        faceZone fluidFaces;
        cellZone fluidZone;
        cellZoneInside insidePoint;
        insidePoint (-10 0 0);
    SolidDomain.stl
        name solid;
        faceZone solidFaces;
        cellZone solidZone;
        insidePoint (-10 0.240 0);
// Settings for the castellatedMesh generation.
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 2000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 4444000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 0;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.0;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 5;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
            file "FluidDomain.eMesh";
            level 4;
            file "SolidDomain.eMesh";
            level 4;
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
    fluid
            cellZone fluidZone;
        level (2 2);
        solid
            cellZone solidZone;
        level (2 2);
    // Resolve sharp angles
    resolveFeatureAngle 30;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //   wanted refinement level. The distances need to be specified in
    //   descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //   cells inside the surface get refined up to the level. The surface
    //   needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (-10 0 0);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 10;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 1.2;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 200;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 10;
    // Feature snapping
        //- Number of feature edge snapping iterations.
        //  Leave out altogether to disable.
        nFeatureSnapIter 10;
        //- Detect (geometric only) features by sampling the surface
        //  (default=false).
        implicitFeatureSnap false;
        //- Use castellatedMeshControls::features (default = true)
        explicitFeatureSnap true;
        //- Detect points on multiple surfaces (only for explicitFeatureSnap)
        multiRegionFeatureSnap true;
estang is offline   Reply With Quote
Old   January 8, 2015, 16:43
anonymous
ssss is on a distinguished road
Try to increase the background mesh it is too coarse I think
ssss is offline   Reply With Quote
Old   January 9, 2015, 02:50
Eugen
Thank you for your help.
I increased the level of surface Refinement to 4. The result is attached to this post.
Do you think the axial coarseness makes a problem?
The meshing finished with 95219 faces of non-orthogonality > 65 degrees.
Old   January 9, 2015, 02:58
anonymous
I mean, that you need to refine more the background mesh, this is the background you do with blockMesh before usign snappyHexMesh
Old   January 9, 2015, 04:12
M. C.
student666 is on a distinguished road
Did you check the surface quality with OF tools: surfaceCheck surfaceClean surfaceOrient?
student666 is offline   Reply With Quote
Old   January 9, 2015, 08:20
Eugen
hi student666,
i checked it with surfaceCheck and it's fine.
Old   January 9, 2015, 18:22
M. C.
Well, i suggest you to look for some help here https://sites.google.com/site/snappywiki/snappyhexmesh
Or you try to mesh two domains jndividually, then merging them: mergeMeshes masterCase slaveCase -overwrite
Bye
Old   January 12, 2015, 01:06
Eugen
Thank you i will try it
Companies that lease software & hardware for cloud-based work? Catthan ANSYS 0 June 18, 2014 10:53
Do all CFD analysts have to do some hands-on work except PhDs? e13drd Main CFD Forum 2 March 17, 2014 14:56
OpenFOAM does not work any more! kiddmax OpenFOAM Installation 12 June 25, 2013 02:56
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 12:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 21:03
