[snappyHexMesh] Sanity check on snappyHexMesh with SwiftSnap/Blender
Old   January 8, 2015, 16:45
Default Sanity check on snappyHexMesh with SwiftSnap/Blender
Louis S
lsimons is on a distinguished road
I'm trying to get my feet wet in electrostatic simulation, and was able to run the basic charged wire example. To try and take it further, I made a torus in a cube using Blender and SwiftSnap, and am trying to run the simulation to see the distribution of the field between the two objects.
However, whenever I run the simulation, I only get a uniform cube (although blockMesh, snappyHexMesh, electrostaticFoam, and paraFoam seem to run with no errors). Based on the SwiftSnap pipe example, it seemed like I should make the box faces a mesh, and the taurus outside a seperate patch. Is there something else required to tell snappyHex to use the volume between the two patches?
Thanks,
Louis
lsimons is offline   Reply With Quote
Old   January 12, 2015, 10:47
Louis S
After speaking with papna on #openfoam-irc, I was able to get the internal geometry to show up in paraFoam by increasing the blockMesh resolution. In blockMeshDict, I changed the following line:
hex (4 5 6 7 0 1 2 3) (2 2 2) simpleGrading (1 1 1)
to:
hex (4 5 6 7 0 1 2 3) (8 8 8) simpleGrading (1 1 1)
However, even though electrostaticFoam runs and solves rho and phi with no residuals, there is no volume data for rho or phi after timestep 0.
blender, swiftsnap
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Parallelize snappyHexMesh optimally? Antimony OpenFOAM Meshing & Mesh Conversion 1 May 25, 2016 00:01
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
[snappyHexMesh] snappyHexMesh runs endless - I need general advise TeresaT OpenFOAM Meshing & Mesh Conversion 5 November 17, 2015 02:50
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
