[snappyHexMesh] snappyHexMesh questions???
Old   January 30, 2015, 08:00
Default snappyHexMesh questions???
Eric Liu
liu-t11 is on a distinguished road
hello, I am new here and have a problem when using snappyHexMesh to generate mesh.
the terminal shows ''Point (1.93 3.731 1.243) is not inside the mesh or on a face or edge. Bounding box of the mesh0 0 1.05) (50 50 1.7).''
however, while I change the locationInMesh many times, this problem still exists.
Any help is appreciated !!!
liu-t11 is offline   Reply With Quote
Old   February 8, 2015, 14:38
Svensen is on a distinguished road
The solutions which is helped to me...
When you define the background mesh with blockMeshDict you need to change the definition in such a way that first four points have Xmin coordinate and other four points have Xmax coordinate:
My working example:
vertices
(-15 55 -140)
(-15 105 -140)
(-15 105 -90)
(-15 55 -90)
(35 55 -140)
(35 105 -140)
(35 105 -90)
(35 55 -90)
blocks
hex (0 1 2 3 4 5 6 7) (20 20 20) simpleGrading (1 1 1)
As you see we start from (Xmin, Ymin, Zmin), then move to (Xmin, Ymax, Zmin), then to (Xmin, Ymax, Zmax) the to (Xmin, Ymin, Zmax)
This steps repeat for Xmax plane.
I think that will work for your case. Try this algorithm )
Svensen is offline   Reply With Quote
Old   March 3, 2015, 02:20
Eric Liu
Well, thank you for reply! I will try later~~~
Old   March 3, 2015, 16:57
Christos
cbarmpar is on a distinguished road
Hi Eric,
I am not sure if you found a solution to your problem.
In case you didnt you can try the following :
Delete the blockMesh related files and regenerate the block mesh
I am not sure if your blockfile definition is correct.
The definition needs to be in cyclic form :
xmin ymin zmin
xmax ymin zmin
xmax ymax zmin
xmin ymax zmin
xmin ymin zmax
xmax ymin zmax
xmax ymax zmax
xmin ymax zmax
cbarmpar is offline   Reply With Quote
[snappyHexMesh] some basic questions about snappyhexmesh fatemehfarshi62 OpenFOAM Meshing & Mesh Conversion 0 January 3, 2016 03:29
[snappyHexMesh] OFW10 snappyHexMesh Training Session Questions (follow up) chegdan OpenFOAM Meshing & Mesh Conversion 3 July 20, 2015 11:10
[snappyHexMesh] questions about snappyHexMesh xurenyi OpenFOAM Meshing & Mesh Conversion 0 June 11, 2014 02:53
[snappyHexMesh] some questions in SnappyHexMesh Cloudy1988 OpenFOAM Meshing & Mesh Conversion 1 August 23, 2012 13:56
[snappyHexMesh] A few simple questions about SnappyHexMesh. suitup OpenFOAM Meshing & Mesh Conversion 1 December 19, 2009 14:30
