[snappyHexMesh] How to improve mesh around delta wing?
Old   February 4, 2015, 15:26
Default How to improve mesh around delta wing?
pizzaspinate is on a distinguished road
Hi Foamers,
I am relatively new to OpenFoam and currently a bit stuck using snappy hex mesh.
I try to mesh a delta wing in with snappy hex mesh but im not happy with the results I got so far. But I have no idea what to change to get a better result at the leading and trailing edge nor how to get layers around the entire aerofoil. I already read some posts here and on the openfoam web page and tried to apply them for my case but with little success.
I have attached some pictures and my snappyHexMeshDict. Maybe someone could give me some advices on what to do because I am absolutely stuck.
Thank you very much in advance for your help.
pizzaspinate is offline   Reply With Quote
Old   February 4, 2015, 18:27
Peter
opedrofunk is on a distinguished road
It looks like you don't quite have adequate refinement in the background grid. I would suggest:
1) Increase the resolution in your blockMeshDict. You can do this "locally" if you define multiple blocks (hex's).
2) Create a "refinementSurface" in the snappyHexMeshDict to progressively increase refinement as a function of distance around your surface. This allows you can set multiple refinement levels at specified distances from the surface;
3) Alternatively, or in combination with (1,2), you might specify a refinementBox which encloses your geometry of interest and apply additional refinement that way.
4) Then have a look at the way you are adding "layers" in the snappyHexMeshDict .
Remember, you can mesh in stages with snappyHexMesh. So if you can get a good castellated mesh, then the snapping is much easier. And when you have a decent "snapped" mesh, the layers will be much easier to add.
You control which steps of the process you run in the dict by setting them to true/false, so you don't have to regenerate each step in the process every time you want to try something, i.e.:
castellatedMesh true;
snap            true;
addLayers       false;
And, if you run snappy without the -overwrite flag, you can see how each step of the process is performed in paraview. That might help give you a more clear picture of what each process in snappy does, i.e.:
$ snappyHexMesh
instead of:
$ snappyHexMesh -overwrite
You may need experiment with different options, but that should get you going in the right direction.
Hope that helps!
Peter
PS: Alternatively, if you are ok with working with tet cells, you might try something like this:
https://extensions.sketchup.com/en/c...y-tetgen-tools in combination with a FoSS mesher like tetgen.
opedrofunk is offline   Reply With Quote
Old   February 5, 2015, 04:35
Thank you for the quick response I will try your recommendations.
I have also tried multiple blocks (see attached blockMeshDict) but if I use snappy then it deletes some blocks leaving me with one small block where only half of the geometry is inside (see attached pictures).
I posted here earlier asking why that is as I have my mesh location point in Snappy Hex mesh defined at the outermost point of the box.
I got told that this meshing strategy is not working for snappy.
Do you have any advice? Do I have to merge the patches in the blockMesh or do I have to put a certain parameter into snappy so this does not happen?
Old   February 5, 2015, 15:21
Peter
It looks like there may be some issues with the way you have your hexes defined or numbered. I tried running blockMesh with your blockMeshDict and got the following error:
$ blockMesh
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : blockMesh
Date   : Feb 05 2015
Time   : 10:54:16
Host   : "Peters-MacBook-Pro.local"
PID    : 2558
Case   : /Users/peter/Desktop/of-mesh
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Creating block mesh from
    "/Users/peter/Desktop/of-mesh/constant/polyMesh/blockMeshDict"
Creating curved edges
Creating topology blocks
Creating topology patches
Creating block mesh topology
--> FOAM FATAL ERROR:
face 0 in patch 0 does not have neighbour cell face: 4(0 12 15 3)
    From function polyMesh::facePatchFaceCells(const faceList& patchFaces,const labelListList& pointCells,const faceListList& cellsFaceShapes,const label patchID)
    in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 127.
FOAM aborting
So, I built a contrived example using multiple hex blocks and a simple sphere for the obstacle (you could, or course, replace this with whatever you want.
The geometry looks like this (similar to what you are working toward, I think?):
http://imgur.com/BOvZSDm
The blockMesh looks like this:
http://imgur.com/91eMv11
The final mesh on the surface of the sphere looks like this:
http://imgur.com/r0v8yt4
The final mesh (clipped through cross section) looks like this:
http://imgur.com/aRqBgHx
http://imgur.com/4tsHoEx
You can control the gradation and refinement of the mesh easily in the snappyHexMeshDict - see the attached case file.
Hope this helps!
Peter
Old   February 6, 2015, 06:41
Hey,
this helps a lot!!! Thank you so much!! I just had a quick look at it but will have closer one on monday when I have my computer back
Old   February 11, 2015, 06:16
I have adjusted your blockMesh so it fits to my case it is working fine (haven't put in boundary faces so far though).
I was just wondering if I have to follow certain rules when creating multiple blocks or if the order does not matter.
My snappy mesh with layers looks still a bit funny though. I think it is due to change in chord length and twist of my wing (see attached picture). Do you know by any chance if it would improve my results if I have two blocks; one for the wing section until the kink and one from the kink to the tip. Or won't it improve the mesh at all?
Thank you very very much again for helping me out with the block mesh!!!!! I was absolutely stuck before!!!
Old   February 11, 2015, 06:17
uups forgot to attach the picture
Old   February 11, 2015, 18:19
Peter
No problem - happy to help.
I think, in general, you probably want to keep your blockMesh as simple as possible, since you can control refinement very well with snappyHexMesh.
The main reason I would make a blockMesh that is anything other than a single hex is to control the orientation and flow-wise alignment of the background mesh. This can be helpful when you know a priori the general direction of flow in regions of interest - and ultimately controls the orientation of what is produced from snappy.
Here is a relatively poor but simple example:
Then experiment with refinement options in snappy (refinementBox, surfaces, features, etc...) to get the mesh density you desire for the regions of interest.
Good luck!
Peter
Old   March 7, 2016, 02:34
Default Meshing of delta wing
Abhishek Kumar
Emstar is on a distinguished road
Can u describe meshing method to get close values of variation of lift and drag coefficients with AOA for delta wing..Is it d same as u described for above problem..plz help
Emstar is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh no layers and no decent mesh for complex geometry pizzaspinate OpenFOAM Meshing & Mesh Conversion 1 February 25, 2015 07:05
Mesh motion with Translation & Rotation Doginal CFX 2 January 12, 2014 06:21
mesh missing after export in gambit morteza08 ANSYS Meshing & Geometry 1 July 26, 2010 01:10
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Delta Wing Structured Grid Riaan FLUENT 3 December 31, 2004 12:03
