[snappyHexMesh] SnappyHexMesh, meshing problem with multiple stl's |
March 30, 2015, 08:19 |
Frank
Hey everybody,
i'm trying to mesh an empty space within multiple geometries, different stl's. There is a closed hollow cylinder (tube-like), built up with four stl files. The fifth geometry is embedded in the inside. In fact, the internal mesh is correctly snapped (see attached picture). The embedded geometry is very close to the walls of the cylinder, but they do not touch or intersect each other. The problem that occurs: At some positions the internal mesh is interrupted, the wall from the cylinder is meshed together with the embedded geometry. It looks like a gate system (see second picture). The distance between the geometries is nearly constant but it only occurs at a few positions. The rest of the cylinder is fine. Does anybody have an idea where this problem may come from? Thanks a lot, Frank |
[snappyHexMesh] snappyHexMesh <-> dynamicMeshDict problem with protected cells | Billy_16 | OpenFOAM Meshing & Mesh Conversion | 2 | November 21, 2020 03:34 |
[ICEM] Asking for help! How to make biased mesh at multiple locations in swept meshing | harryosu | ANSYS Meshing & Geometry | 3 | January 29, 2016 02:56 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 22:04 |
[ICEM] Problem with meshing half NACA0009 in 3D | Eizo | ANSYS Meshing & Geometry | 30 | February 17, 2013 02:40 |
GAMBIT meshing problem | Gauthier Lambert | Main CFD Forum | 1 | August 3, 2000 09:22 |
