July 21, 2015, 11:46 |
Error when running SHM
Rep Power: 11 |
Hi everyone,
for an upcoming project I need the snappHexMesh tool. I read the User guide, watched tutorials but now I'm having a hard time to proceed with the provided iglooWithFridges tutorial! When running SHM the following error occurs: Code:
dyld: Symbol not found: __SCOTCHbgraphbipartststratab Referenced from: /usr/local/opt/scotch/lib/libptscotch.dylib Expected in: flat namespace in /usr/local/opt/scotch/lib/libptscotch.dylibTrace/BPT trap: 5 By the way I work with OF Version 2.3.0 on Mac 10.9.5 Any help is much appreciated! Best regards, Arnolnic |
July 29, 2015, 08:41 |
Rep Power: 11 |
Anyone having the same issue, take a look at this post - Solution to the problem -
P.S. credit goes to alexeym! |
[foam-extend.org] Foam Extend 3.2 in ubuntu 16.04 LTS | JMosiezny | OpenFOAM Installation | 15 | December 9, 2017 08:20 |
[snappyHexMesh] SHM for meshing plane surface without morphological changes | alinuman15 | OpenFOAM Meshing & Mesh Conversion | 0 | October 27, 2017 08:32 |
Problem in running coarse mesh(on the other hand fine mesh is running) | ashokmoravaneni | OpenFOAM | 7 | July 17, 2017 04:56 |
[snappyHexMesh] different sHM results on same geometry when everythin is in one or several stl-files. | Laika | OpenFOAM Meshing & Mesh Conversion | 1 | September 8, 2016 04:09 |
OpenFOAM parallel on VM? pimpleDyMFoam propeller tutorial has been running for hours. | MBttR | OpenFOAM Running, Solving & CFD | 0 | June 13, 2016 10:58 |
