[snappyHexMesh] snappyHexMesh runs endless - I need general advise |
November 16, 2015, 04:06 |
Teresa
Rep Power: 10 |
Hello everyone!
First things first I am a student from Germany with just a little bit experience with openFoam. I will always be thankful if you answer with links to pages where I can find answers as i tried to find them without luck so far. Even tips on what keywords will work, or which book to read will be welcome. The Problem: snappyHexMesh runs and runs and runs.. way over 12 hours so far The goal: To set up a kwSST Case to simulate the flow around the "Berliner Fernsehturm" the tv tower at Alexanderplatz, Berlin, Germany. The case right now: For my first attempt with snappyHexMesh I made a imprecise stl of the tv tower and i used the motorbike example files. A few times snappyHexMesh worked well however I made mistakes and ended up with a mesh that contained only a few parts of my tvtower.stl. I was able to find a solution on my own. The tvtower is now located in the middle of my blockMesh generated block, just where I think it should be. The mesh of my block is already quite fine. My General questions: 1. mesh of the outer block: Does the amount of cells interfere with snappyHexMesh? Is there a rule to identify the number of useful cells? 2. stl-File: What can I do to improve my stl file? Whatīs easier to mesh? Sharp edges or smooth roundings? Right now the stl contains both, should I change it to one type only? 3. Further readings: Can you recommend a book fur further readings? One with a highly detailed chapter about snappyHexMesh? Thanks to everyone who has read so far, every hint is welcome. Greetings, Teresa Ps.: Prior cases using only blockMesh and laminar flow worked well so far. |
beginners, blockmesh, snappyhexmesh |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
Strange Results With snappyHexMesh | calebamiles | OpenFOAM Running, Solving & CFD | 0 | August 14, 2011 16:02 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
