January 19, 2010, 04:17 |
2D snappyHexMesh
wong
Rep Power: 16 |
Dear all,
I try to simulate wind flow throung a sing building in OpenFOAM, in order to save some running time, I simulate it as a 2D case. However, the snappyhexMesh is not applicable in 2D simulation because it will not only refine in x and y direction, but also in z direction, there make my blockMesh has more then one layer of cell in z direction, do someone have some tool for 2D snappyHexMesh? Or do someone have idea for my question? Thx, wind_FYP |
January 20, 2010, 06:14 |
extrudeMesh
Michael Roth
Rep Power: 17 |
Perhaps you could snappyHexMesh your geometry and then use extrudeMesh to extrude one layer from the surface representing your 2D geometry. Just keep the layer.
Mike |
January 21, 2010, 04:37 |
wong
Rep Power: 16 |
thx, Mike
But can you tell me how to use 'extrudeMesh ' in detail, because I have not used before. wind_FYP |
September 27, 2010, 13:00 |
ms
Rep Power: 17 |
Hi Wind_fyp,
Did you get your job working? I'm in the same position and am wondering what the best approach is. There seems to be a distinct lack of two-dimensional snappyHexMesh posts! Cheers, Mark. |
[CAD formats] Creating waterproof STL using snappyHexMesh or salome | Tobi | OpenFOAM Meshing & Mesh Conversion | 58 | May 13, 2020 06:01 |
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing | peterhess | OpenFOAM Meshing & Mesh Conversion | 2 | January 3, 2018 02:54 |
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. | jasv | OpenFOAM Meshing & Mesh Conversion | 4 | May 10, 2016 02:55 |
[snappyHexMesh] snappyhexmesh doesn't creat mesh in parallel issue? | klausb | OpenFOAM Meshing & Mesh Conversion | 1 | March 7, 2015 11:55 |
[snappyHexMesh] stitchMesh and snappyHexMesh | gdbaldw | OpenFOAM Meshing & Mesh Conversion | 0 | December 23, 2009 02:09 |
