[Netgen] Ellipsoids at an angle
Old   October 25, 2010, 14:56
Default Ellipsoids at an angle
Stuart
beefstu is on a distinguished road
Hi all,
I'm trying to mesh an ellipsoid positioned at an angle but cant seem to get it to work. The .geo that I'm trying is as follows:
algebraic3d
solid ellips1 = ellipsoid (0.0,0.0,0; 3.9392310120488321,0,0.69459271066772166; 0,4,0; 1.7364817766693041,0,9.8480775301220795);
tlo ellips1;
To explain what i did, basically its fine generating an ellipsoid on one of the axes so to try to rotate it slightly, I used trigonometry to work out the new positions of the axes of the ellipsoid, hence the long floats, this should be rotated by 10deg anticlockwise which seems to be what it has done except it has huge holes in it and won't mesh!
For information, the formulae used are as follows:
ellipsoid (0.0,0.0,0; 4sin(80),0,4cos(80); 0,4,0; 10cos(80),0,10sin(80));
I would appreciate any pointers!
Many thanks
Stu
beefstu is offline   Reply With Quote
Old   October 27, 2010, 17:05
Stuart
ok solved this myself - was being foolish with the vectors, the 10cos(80) should have been negative, was a self-inflicted error, nothing to do with Netgen!
Dynamic contact angle calculation in multiphaseInterFoam rajeshchem OpenFOAM 3 December 23, 2022 14:00
Dynamic contact angle issue: fluent UDF couldn't set the correct contact angle FelixJJ FLUENT 2 October 20, 2021 02:39
Winglet cant angle effects frossi FLUENT 0 March 31, 2017 19:35
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
Normal vector, slope and aspect angle g_niro Main CFD Forum 0 February 2, 2011 17:24
