December 15, 2010, 10:57 |
Meshing multiple blocks
Hannes
Rep Power: 15 |
Hello Foamers!
I needed to create a wall bonded Cube with an outlet that covers the hole backward face and an inlet which is only a small rectangular opening at the middle of the front face. The rest of the front face is defined as wall. In order to do this, i needed to create multiple blocks with BlockMesh (at least i dont know any other way). Ive made a very raw front view sketch of the block structure i created. The red face is the inlet. The problem that occurs now, is that SnappyHexMesh is meshing only the BlockMesh defined block which contains the LocationInMesh point. Strangely it meshes all of the middle blocks if the LocationInMesh point is inside the red block. But not the side blocks. I wonder if its one of those paraFoam displaying bugs, but it seems not to be. I figure it is because im using distance wise meshing of the STL, which overlaps all of the three middle blocks but not the side blocks. So my question is, is there a way to mesh multiple blocks with blockmesh? Thanks for your help. Hannes. Edit: I tried to work it out by defining a refinment box big enough to overlap all blocks, but it didnt work. Last edited by Hanno; December 15, 2010 at 11:18. |
[Commercial meshers] fluent3DMeshToFoam | bego | OpenFOAM Meshing & Mesh Conversion | 31 | August 16, 2023 09:04 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[ICEM] multiple processor meshing in batch mode | Jonathan | ANSYS Meshing & Geometry | 6 | August 14, 2013 14:40 |
[blockMesh] How to use multiple blocks | marico | OpenFOAM Meshing & Mesh Conversion | 0 | March 23, 2009 05:03 |
Meshing support parallel multiple computers! | Kevin | Siemens | 1 | July 26, 2007 19:27 |
