[mesh manipulation] makeAxialMesh - installation issues
Old   March 14, 2012, 05:13
Question makeAxialMesh - installation issues
Burner
simulator4711 is on a distinguished road
i want to install MakeAxialMesh, but the result when calling the program with "makeAxialMesh" is always "command not found". I tried a lot and read forums without success. I am relatively new to Linux, so there may be a easy solution i do not know.
Here is my setup:
The given computer has OF2.01 installed at
ThinkPad-Edge:/opt/openfoam201$
I changed to the folder
ThinkPad-Edge:/opt/openfoam201/applications/utilities/mesh/manipulation/
and executed
sudo svn checkout https://openfoam-extend.svn.sourcefo.../MakeAxialMesh
Then it was installed at:
ThinkPad-Edge:/opt/openfoam201/applications/utilities/mesh/manipulation/MakeAxialMesh$
Within this folder, there is another folder named "makeAxialMesh".
But i can't call the programm with "makeAxialMesh". Do i need to add something to the $HOME/.bashrc or the other bashrc located somewhere in the openfoam folder? What did I do wrong? Thanks a lot for helping!!
simulator4711 is offline   Reply With Quote
Old   March 20, 2012, 09:18
Assistant Moderator
Bernhard Gschaider
Originally Posted by simulator4711 View Post
Here is my setup:
and executed
Have you compiled it? Then it should be in your PATH (FOAM_USER_APPBIN to be specific)
Old   March 21, 2012, 07:19
Burner
I executed the line given in the download section:
That's all - is it right? Is ist "compiled"?
I found no Path FOAM_USER_APPBIN. Is it installed with OF or do i need to create it somewhere? Should i execute the above mentioned line in this directory? Thanks a lot!
Old   March 21, 2012, 07:59
Assistant Moderator
Bernhard Gschaider
No. You downloaded the sources. Compilation is done with the command wmake in the directory which has a subdirectory called Make. See the UserGuide section 3.2 for details on utility compilation
FOAM_USER_APPBIN is an environment variable and the contents of that directory can be accessed with
echo $FOAM_USER_APPBIN
(but that is non-OF-specific)
Bernhard
makeaxialmesh
Installation issues on Ubuntu 13.10 Jeggi enGrid 14 July 22, 2023 06:13
[swak4Foam] installation issues with foamextend3.2 srivatta OpenFOAM Community Contributions 2 January 22, 2017 12:51
[foam-extend.org] issues with extend-3.2 installation on ubuntu CjjJoy OpenFOAM Installation 0 July 18, 2016 08:58
[Other] Installation issues with flex 2.6.0 and inelegant solution windscion OpenFOAM Installation 1 January 18, 2016 14:18
Installation issues for parallel computation Akash C SU2 Installation 1 June 21, 2013 05:26
