[snappyHexMesh] Strange distance-based refinement |
December 22, 2011, 09:53 |
Rep Power: 16 |
I am trying to use two levels of distance-based refinement in relation to a surface. It seems like I've done this successfully before, but all of the sudden I cannot get this strange behavior to go away.
I've attached my snappy dict and an image of the refinement. Thanks for any hints. |
December 23, 2011, 05:06 |
Rep Power: 16 |
everything is fine with your refinement. It's just the way you visualize the mesh. Instead of "slice" try this: Apply the Extract Cells By Region filter, check the boxes for "Extract only intersected" and "Extract intersected". Toni
"When I meet God, I am going to ask him two questions: Why relativity? And why turbulence? I really believe he will have an answer for the first." Werner Heisenberg
[snappyHexMesh] snappyHexMesh can't create refimenet region | clktp | OpenFOAM Meshing & Mesh Conversion | 3 | February 27, 2022 09:26 |
[snappyHexMesh] Snappy creates strange cells far away from boundary | vainilreb | OpenFOAM Meshing & Mesh Conversion | 3 | December 16, 2020 05:11 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
