[Technical] High aspect ratio microchannel
Old   November 16, 2012, 05:19
Default High aspect ratio microchannel
michel
michel2008 is on a distinguished road
Hello all
I am trying to simulate laminar flow in a microchannel with high aspect ratio about 500 for a microchannel with 2 micron depth and I can not reduce the element size less than 3 micron because of the out of memory problem. When I tried 3 micron element size in the body, the results do not validated by analytical. Is there any help to solve this problem?
Thanks,
michel2008 is offline   Reply With Quote
high aspect ratio, microchannel
[TGrid] High Aspect Ratio in Turbogrid Julian121 ANSYS Meshing & Geometry 0 September 24, 2018 09:45
[ANSYS Meshing] High Aspect Ratio Geometry jreiter164 ANSYS Meshing & Geometry 0 October 19, 2015 23:44
[ANSYS Meshing] High aspect ratio Roby_1986 ANSYS Meshing & Geometry 0 February 22, 2013 05:34
use of high aspect ratio cells near walls Usman FLUENT 0 January 23, 2008 07:16
Aspect Ratio at high turbulent and swirled flows zago FLUENT 0 May 19, 2004 02:37
