[mesh manipulation] Refine an area defined by non-primitive geometry
Old   December 4, 2015, 20:55
Default Refine an area defined by non-primitive geometry
Brad Perfect
bhperfect is on a distinguished road
I would like to run refineMesh on an area that can be approximated by two boxes.
How do I define a cellSet in topoSetDict that includes the cells contained within these two boxes?
This should be a simple syntax issue, but my google-fu has failed me. Currently I have:
actions ( {
name c0;
type cellSet;
action new;
source boxToCell'
sourceInfo {
(x1 y1 z1) (x2 y2 z2);
bhperfect is offline   Reply With Quote
Old   December 7, 2015, 19:43
Brad Perfect
I've been playing around in the setSet environment and the commands appear to function intuitively there. However, in topoSetDict, I'm still getting really irrational behavior.
cellset c0 new boxToCell (a b c) (d e f)
cellset c0 add boxToCell (g h i) (j k l)
functions perfectly well in setSet, but I have no idea how to translate this into something that topoSet will understand. I'm working in OF 2.3.
Does anyone have any recommendations?
Old   December 7, 2015, 20:05
Brad Perfect
The TL;DR solution for posterity is that OpenFOAM cares A LOT about white space.
boxToCell(a b c) (d e f);
is very different from
boxToCell (a b c) (d e f);
Non overlap area fractions saisanthoshm88 CFX 11 September 17, 2015 18:42
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
Simulation of Flow through Complex 3D Geometry EmersonKB CFX 5 July 2, 2009 08:17
vitual _ real deneb FLUENT 3 January 22, 2007 04:31
Virtual/Real geometry. Jack Keays FLUENT 9 June 15, 2000 23:39
