[Technical] Plot3DtoFoam conversion error
Prev Previous Post   Next Post Next
Old   March 29, 2008, 06:03
Default Plot3DtoFoam conversion error
Leonardo Nettis
dinonettis is on a distinguished road
Hi everybody,
I'm trying to import a 2d naca profile written in Plot3d but I get the following error:
Exec : plot3dToFoam /home/dino/OpenFOAM/dino-1.4.1/run/tutorials/potentialFoam/ nacaPotential naca_0012.xyz
Date : Mar 29 2008
Time : 11:51:46
Host : ime054
PID : 5316
Root : /home/dino/OpenFOAM/dino-1.4.1/run/tutorials/potentialFoam/
Case : nacaPotential
Nprocs : 1
Create time
Reading 1 blocks
xDim:257 yDim:129 zDim:1
Reading block points
block 0:
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: naca_0012.xyz at line 5.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
I don't know if this utilities needs a 3d mesh to convert, but if I remember correctly openfoam automatically introduce a third dimension.
Thank you in advance for any support.
dino
dinonettis is offline   Reply With Quote
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 00:21
CFD by anderson, chp 10.... supersonic flow over flat plate varunjain89 Main CFD Forum 18 May 11, 2018 07:31
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 06:42
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
