[mesh manipulation] How to visualize certain Cells??
Old   November 18, 2012, 12:28
Default How to visualize certain Cells??
hfs
hfs is on a distinguished road
I guess this one is an easy question .. forgive my little experience with OpenFOAM.
CheckMesh has given me these types of cells:
Overall number of cells of each type:
    hexahedra:     501645
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     13968
I want to visualize the 13968 polyhedra cells...
I guess I can make a cellSet containing them ... maybe using setSet.. and then I will be able to use foamToVTK to see them in paraview
The Question is: how can I make that polyhedra cellSet? I have no experience with setSet..
Thank you for your help!
Regards,
hfs is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 91 December 21, 2022 04:50
[blockMesh] Create internal faces as patch in blockMesh m.delta68 OpenFOAM Meshing & Mesh Conversion 14 July 12, 2018 14:43
[snappyHexMesh] Problem: after snappyHexMesh, the cells size are not the same kanes OpenFOAM Meshing & Mesh Conversion 0 January 25, 2016 08:06
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
snappyhexmesh remove blockmesh geometry philipp1 OpenFOAM Running, Solving & CFD 2 December 12, 2014 10:58
