[mesh manipulation] Mapping mesh from cartesian coordinates to cylindrical coordinates |
December 10, 2013, 10:31 |
Matteo Pellegri
Good morning everybody,
I solved the pressure field in the gap between the shaft and the bearing inside a journal bearing: to solve it I used a cartesian coordinates system (basically I unwrapped the fluid film domain) and now I would like to map the results on the cylindrical domain to visualize it in paraView. Any suggestions? Thanks a lot. |
cylindrical annulus, mapping, mapping plot3d, remapping |
Finite Volume Method For Cylindrical Coordinates | falopsy | Main CFD Forum | 45 | August 14, 2023 21:14 |
decomposePar problem: Cell 0contains face labels out of range | vaina74 | OpenFOAM Pre-Processing | 37 | July 20, 2020 05:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
