[mesh manipulation] DynamicMesh - Move internal points
Old   September 4, 2014, 15:29
Default DynamicMesh - Move internal points
nucat is on a distinguished road
Hallo foamers,
actually I am programming an y+ adaption for OpenFoam. I need a tool, which manipulates the mesh by making the thickness of the first boundary layer smaller if there is detected y+>1.
I am able to detect that vertices with toposet:
  • select all faces with y+>1
  • select all cells with that selected faces
  • select points of the selected cells (first boundary layer)
  • deselect points of the boundary face
The result is a selection of points of the first boundary cells, but not points directly of the boundary (they have to stay fixed). Now I want to move them down and want to do it with dynamicMesh library.
Problem: I didn't find in the web a tutorial, how to move internal points (not boundary points) of the mesh. Do anybody knows how it works?
Thanks for help,
Nucat
nucat is offline   Reply With Quote
Old   September 4, 2014, 18:35
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
If you look at the layeredEngineMesh code, you can see there is code that moves certain mesh points to a new position based on the calculated crank angle. You will need to do something similar, although I don't quite know how you would determine the new position.
It would have to be some kind of function that finds distance to the nearest point on a boundary patch, then takes a fraction of the distance along the vector to the nearest point on the patch and moves the new point to that position (like half the distance?). Or just a set distance along that line. There are some built in functions like that in meshTools and other libraries. Its been a while since I've had to do anything with them.
mturcios777 is offline   Reply With Quote
Old   September 6, 2014, 08:54
Hey,
thanks for reply. I think I will solve that problem by myself with toposet and python ))
dynamic mesh
[snappyHexMesh] Layers not growing at all zonda OpenFOAM Meshing & Mesh Conversion 12 June 6, 2020 11:28
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
PrimitivePatch movePoints() didnt move the points tiat OpenFOAM 0 July 21, 2015 09:57
dynamicMesh - move surface due to velocity/pressure Tobi OpenFOAM Running, Solving & CFD 5 November 1, 2014 14:18
Constraining internal points to be specific velocities choonhwai OpenFOAM Pre-Processing 0 August 12, 2013 04:58
