[snappyHexMesh] SnappyHexMesh region deletion
Old   February 13, 2009, 12:10
Default SnappyHexMesh region deletion
Simon Hubbard
monkeytron is on a distinguished road
Hi All,
I'm trying to use snappyHexMesh to do some quite complex meshing with lots of cells. I am starting with an STL that is an enclosed volume inside my blockMesh generated mesh. I am only interested in the resulting mesh inside the enclosed STL, but it seems that sHM does lots of refinement/effort before deleting the region of mesh you have told it you dont want. This is causing me to run out of memory, so I was wondering if there is any way to only do the refienment/effort in the region I want, rather than spending effort requiring storage for fine mesh that subsequently gets deleted?
Thanks,
Simon.
monkeytron is offline   Reply With Quote
Old   February 18, 2009, 08:31
Default check your refinement Mode und
Wolfgang Heydlauff
wolle1982 will become famous soon enough
check your refinement Mode under
"refinementRegions" in the sHMDict
maybe you are still on mode "distance". maybe you'd better use "inside" or "outside"
Specifies refinement level for cells in relation to a surface. One of
three modes
- distance. 'levels' specifies per distance to the surface the
wanted refinement level. The distances need to be specified in
descending order.
- inside. 'levels' is only one entry and only the level is used. All
cells inside the surface get refined up to the level. The surface
needs to be closed for this to be possible.
- outside. Same but cells outside.
wolle1982 is offline   Reply With Quote
Old   February 19, 2009, 22:57
Default Hi Simon, I think the only
Kati Laakkonen
kati is on a distinguished road
Hi Simon,
I think the only way to limit the memory consumption in surface refinement phase would be to try to limit the background mesh size by making it follow your geometry. A bit unorthodox suggestion, but do you have access to mesh generator which could create you a stair-step mesh that just encloses your geometry?
Regards,
Kati
kati is offline   Reply With Quote
Can I use fvOptions to couple a solid region and a fluid region? titanchao OpenFOAM Running, Solving & CFD 4 January 14, 2022 07:55
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 15:53
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 05:07
[snappyHexMesh] multi region with snappyHexMesh vikthor OpenFOAM Meshing & Mesh Conversion 0 August 24, 2012 03:47
