[snappyHexMesh] SnappyHexMesh One instead of two zones
Old   November 5, 2008, 07:54
Default SnappyHexMesh One instead of two zones
BastiL
bastil is on a distinguished road
Hi all,
I run snappyHexMesh on a fairly complex geometry. However, the geometry (triangular surface mesh) is 100% closed and manyfold as it has been used for t-grid before. Snappyhexmesh always produces one cell zone wich is inside and outside of my geometry. However I expect only the outside part to be kept.
This means snappy thinks my geometry has a hole, right? How can I find the problematic area in the surface?
Thanks BastiL
bastil is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh: Face is in multiple zones P Greene OpenFOAM Meshing & Mesh Conversion 5 January 27, 2024 15:45
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! divergence OpenFOAM Meshing & Mesh Conversion 0 January 23, 2019 04:17
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] SnappyHexMesh fails with internal Zones chossfeld OpenFOAM Meshing & Mesh Conversion 1 January 27, 2011 08:29
