[Gmsh] Tube in a tube how to model
Old   June 4, 2007, 12:17
Default Tube in a tube how to model
Simon Stapleton
tufty is on a distinguished road
Hi. After successfully playing with OpenFOAM for a couple of 2d decompositions of my problem domain, I now want to go for a fully-3d approach.
The model in question is relatively complex, featuring:
An enclosed "pot" (basically, a cylinder with one closed end and a tapered cylinder open to the atmosphere "stuck on" the other end. this much is easy enough to model using the "classic" square core and 4 segments approach.
"Free floating" inside the pot, with both ends open (i.e not touching either end), a baffle, with its exterior a tapered cylinder and the interior "streamlined". this is a 3d structure, not a simple 2d baffle, if that matters.
I figured I could extend the "square core with 4 segments" to "square core with 4 segments and an additional 4 segments", but it seems to be causing problems with the "interior" arc segments, blockMesh seems to think the arc points are colinear.
Is this a known problem, and if so, does anyone have any ideas as to how I could solve it?
Simon
tufty is offline   Reply With Quote
Old   June 5, 2007, 08:29
Default Here's a snapshot of the pot a
Simon Stapleton
Here's a snapshot of the pot as modelled in gmsh (not, I might add, as I was trying to do things, the msh file itself doesn't want to import)
Old   June 5, 2007, 10:57
Default Meh. Forget it. I managed to
Simon Stapleton
Meh. Forget it. I managed to get gmsh to export an mesh gmshToFoam liked by - ahem - remembering to name my volumes as well as my surfaces.
Onwards and upwards
Simon
Which Multiphase Model Should be selected in Fluent for my below described simulation oberstar Fluent Multiphase 0 September 28, 2017 12:05
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
2D model of a tube in tube heat exchanger in fluent raveesh FLUENT 1 July 9, 2014 08:11
