[blockMesh] What does it mean?
Old   August 13, 2009, 12:12
Default What does it mean?
Miro
Miroo is on a distinguished road
I put the data in blockMeshDict:
*--------------------------------*- C++ -*----------------------------------*\
| \\ / O peration | Version: 1.5 |
| \\ / A nd | Web: http://www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(0 0 0) //0
(0.001 0 0)//1
(0.001 0.001 0)//2
(0 0.001 0)//3
(0 0 0.01)//4
(0.001 0 0.01)//5
(0.001 0.001 0.01)//6
(0 0.001 0.01)//7
(0 0 0.011)//8
(0.001 0 0.011)//9
(0.001 0.001 0.011)//10
(0 0.001 0.011)//11
(0.006 0 0.011)//12
(0.006 0 0.01)//13
(0.006 0.001 0.01)//14
(0.006 0.001 0.011)//15
blocks
hex (0 1 2 3 4 5 6 7) (5 5 50) simpleGrading (1 1 1)
hex (4 5 6 7 8 9 10 11) (5 5 5) simpleGrading (1 1 1)
hex (5 6 10 9 12 13 14 15) (25 5 5) simpleGrading (1 1 1)
edges
patches
patch inlet
(3 2 1 0)
patch outlet
(15 12 13 14)
wall walls
(5 1 2 6)
(6 2 3 7)
(3 7 4 0)
(0 1 5 4)
(4 5 9 8)
(9 10 11 8)
(8 11 7 4)
(10 6 7 11)
(10 15 14 6)
(9 12 15 10)
(9 5 13 12)
(5 6 14 13)
mergePatchPairs
And the message that I get was:
face 8 in patch 2 does not have neighbour cell face: 4(10 15 14 6)
What I can do?
Thanks
Miroo is offline   Reply With Quote
Old   August 14, 2009, 01:26
sega's Avatar
Sebastian Gatzka
sega is on a distinguished road
There don't seems to be anything wrong with the patches.
But maybe you can try to change the third block to
hex (5 6 10 9 13 14 15 12) (25 5 5) simpleGrading (1 1 1)
Schrödingers wife: "What did you do to the cat? It's half dead!"
sega is offline   Reply With Quote
Old   August 14, 2009, 02:33
Default Thanks
Miro
Thank you!
Danke!
Old   August 14, 2009, 07:44
sega's Avatar
Sebastian Gatzka
Originally Posted by Miroo View Post
Thank you!
Danke!
Does that mean it worked?
Old   August 17, 2009, 07:38
Default Hi
Miro
No, but I did an mistake in the points!
Thanks
