[mesh manipulation] extrude2Mesh stucks on error "created illegal face"
Old   September 20, 2010, 04:32
Default extrude2Mesh stucks on error "created illegal face"
Florian Becker
draufunddran is on a distinguished road
Hallo,
in want to run extrude2DMesh onto an 2D-mesh
but when i was trying it with a simple flat 4x4 cells mesh i'm getting an error:
--> FOAM FATAL ERROR:
Created illegal face 2(13 14) at position:50 when filtering removed points
here are the points faces and cells files:
POINTSFILE:
FoamFile
    version 2.0;
    format ascii;
    root "";
    case "";
    instance "constant";
    local "polyMesh";
    class vectorField;
    object points;
25
(0 0 0)
(0.025 0 0)
(0.05 0 0)
(0.075 0 0)
(0.1 0 0)
(0 0.025 0)
(0.025 0.025 0)
(0.05 0.025 0)
(0.075 0.025 0)
(0.1 0.025 0)
(0 0.05 0)
(0.025 0.05 0)
(0.05 0.05 0)
(0.075 0.05 0)
(0.1 0.05 0)
(0 0.075 0)
(0.025 0.075 0)
(0.05 0.075 0)
(0.075 0.075 0)
(0.1 0.075 0)
(0 0.1 0)
(0.025 0.1 0)
(0.05 0.1 0)
(0.075 0.1 0)
(0.1 0.1 0)
FACESFILE:
FoamFile
    version 2.0;
    format ascii;
    root "";
    case "";
    local "polyMesh";
    class faceList;
    object faces;
40
2(0 5 )
2(5 6 )
2(1 6 )
2(0 1 )
2(10 5 )
2(10 11 )
2(11 6 )
2(10 15 )
2(16 15 )
2(16 11 )
2(20 15 )
2(20 21 )
2(16 21 )
2(6 7 )
2(2 7 )
2(1 2 )
2(11 12 )
2(12 7 )
2(16 17 )
2(17 12 )
2(21 22 )
2(17 22 )
2(8 7 )
2(8 3 )
2(2 3 )
2(12 13 )
2(8 13 )
2(17 18 )
2(18 13 )
2(22 23 )
2(18 23 )
2(8 9 )
2(9 4 )
2(3 4)
2(13 14)
2(9 14)
2(18 19 )
2(19 14 )
2(24 23 )
2(24 19 )
CELLSFILE:
FoamFile
    version 2.0;
    format ascii;
    root "";
    case "";
    local "polyMesh";
    class cellList;
    object cells;
16
4(0 1 2 3 )
4(1 4 5 6 )
4(8 9 5 7 )
4(8 10 11 12 )
4(2 13 14 15 )
4(16 17 13 6 )
4(16 9 18 19 )
4(20 18 12 21 )
4(24 22 14 23 )
4(17 26 22 25 )
4(27 25 19 28 )
4(27 21 30 29 )
4(32 33 31 23 )
4(26 35 34 31 )
4(36 34 28 37 )
4(36 38 30 39 )
i don't have any idea why this isn't working please help...
Thanks draufunddran
draufunddran is offline   Reply With Quote
2d mesh, extrude2dmesh, illegal face, utility
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 05:50
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
