[snappyHexMesh] nonManifoldPoints using snappyHexMesh
Old   September 24, 2012, 09:03
Default nonManifoldPoints using snappyHexMesh
Andrea Ferrari
Andrea_85 is on a distinguished road
HI foamers,
i am using snappyHexMEsh to mesh a complex geometry. I am doing some test, varying the number of cells of the backgroud mesh, to see which discretization is better for my simulation. In same cases, when the meshing process is finished, checkMesh returns a nonManifoldPoints warning like the one below
Mesh stats
    faces:            6609516
    internal faces:   5603097
    cells:            2023593
    boundary patches: 7
    point zones:      0
    face zones:       0
    cell zones:       0
Overall number of cells of each type:
    hexahedra:     2008426
    prisms:        0
    wedges:        0
    pyramids:      0
    tet wedges:    0
    tetrahedra:    0
    polyhedra:     15167
Checking topology...
    Boundary definition OK.
    Point usage OK.
    Upper triangular ordering OK.
    Face vertices OK.
    Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
    Patch               Faces    Points   Surface topology
    left                23766    25072    ok (non-closed singly connected)
    right               22929    24290    ok (non-closed singly connected)
    top                 5476     5625     ok (non-closed singly connected)
    bottom              17704    18749    ok (non-closed singly connected)
    front               22057    23326    ok (non-closed singly connected)
    back                23799    25100    ok (non-closed singly connected)
    square_CreatedbyGmsh890688   890541   multiply connected (shared edge)
  <<Writing 10 conflicting points to set nonManifoldPoints
Checking geometry...
    Overall domain bounding box (0.001 0.001 0.001) (0.023 0.03 0.023)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (9.0038e-14 6.34549e-14 3.07148e-15) OK.
    Max cell openness = 2.23352e-16 OK.
    Max aspect ratio = 1.00626 OK.
    Minumum face area = 2.2082e-08. Maximum face area = 8.88927e-08.  Face area magnitudes OK.
    Min volume = 3.29904e-12. Max volume = 2.64278e-11.  Total volume = 7.18693e-06.  Cell volumes OK.
    Mesh non-orthogonality Max: 25.3111 average: 3.25383
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.333842 OK.
Is there a way to avoid or to fix this issue? Does OF complain about that during the simulation? (at the moment i have not tried yet to run a simulation)
I am using OF 2.1.0, but i have also tried 1.7.1 and got the same error.
Best
Andrea
Andrea_85 is offline   Reply With Quote
Old   October 2, 2021, 18:55
Mohammad M F
mmohaqeqf is on a distinguished road
Did OpenFOAM complain about nonManifoldPoint during the simulation?
I am also meshing a relatively complex geometry using sHM, and getting nonManifoldPoints warning?
mmohaqeqf is offline   Reply With Quote
[CAD formats] Creating waterproof STL using snappyHexMesh or salome Tobi OpenFOAM Meshing & Mesh Conversion 58 May 13, 2020 06:01
[snappyHexMesh] Running snappyHexMesh in parallel - optimizing peterhess OpenFOAM Meshing & Mesh Conversion 2 January 3, 2018 02:54
[snappyHexMesh] Tutorial crashes: snappyHexMesh floating point exception. jasv OpenFOAM Meshing & Mesh Conversion 4 May 10, 2016 02:55
Strange Results With snappyHexMesh calebamiles OpenFOAM Running, Solving & CFD 0 August 14, 2011 16:02
[snappyHexMesh] stitchMesh and snappyHexMesh gdbaldw OpenFOAM Meshing & Mesh Conversion 0 December 23, 2009 02:09
