[Technical] how to order the vertices in blockMesh? |
December 11, 2012, 09:50 |
AndreiCFD
Rep Power: 13 |
Hi
Is there any rule regarding the order of the vertices in a blockMesh file. I know that the first entry in the blockmesh file is vertex 0. how do you find 5 6 7 8 ....... I would appreciate your help? Regards |
December 11, 2012, 11:09 |
Rep Power: 14 |
The vertices are in the order you put them in the file.
The first vertex is 0. the next one is number 1 and so on. It's totally up to you. The complicated part is the right declaration of the blocks and patches, because your local coordinate system is defined by the order of the vertices in the block (which isn't necessarily (0 1 2 ..7). More info can be found here: http://www.openfoam.org/docs/user/blockMesh.php |
December 11, 2012, 13:17 |
AndreiCFD
Rep Power: 13 |
thanks man
blockMesh - two blocks with different vertices | Rojj | OpenFOAM Pre-Processing | 3 | March 21, 2023 20:39 |
Help needed! How to continue with 2nd order calculations from 1st order solution? | LeoKnight7 | FLUENT | 4 | July 1, 2016 04:15 |
what's faster, 2nd order eqs from the begining or 1st order and then 2nd order eqs? | TimberJ3 | FLUENT | 0 | April 1, 2014 09:08 |
Unstable flow simpleFoam 2nd order | Valle | OpenFOAM | 0 | August 26, 2009 08:12 |
1st order temporal & 2nd order spatial | Prateep Chatterjee | FLUENT | 0 | January 19, 2003 00:31 |
