[Netgen] Null determinant cells in Netgen
Old   January 20, 2013, 10:55
Default Null determinant cells in Netgen
Daniele Vicario
danvica is on a distinguished road
Meshing a simple geometry using Netgen I obtained some null-determinant cells that crash a solver (see http://www.cfd-online.com/Forums/ope...tml#post402809)
Enclosed you can find pictures of the mesh and the file of the .brep geometry.
The white coloured cells are the null-determinant ones.
Is there anyone able to solve this problem ? Is there any guideline to follow to avoid this cells ?
More: Why did they come in such a simple case ?
Thanks.
Daniele Vicario
blueCFD2.1 - Windows 7
danvica is offline   Reply With Quote
Old   January 24, 2013, 06:23
Default Success in SALOME
Ilya
skeptik is on a distinguished road
I generated both meshes in SALOME without any problem.
1. Simple mesh NETGEN 1D-2D-3D with very fine settings.
2. Mesh with refinement on edges.
I did not mesh conversion due to i have not OF on my working computer, but SALOME didn't detect zero volumes so i think there is no elements with negative determinant.
P.S. I use SALOME on Win7
skeptik is offline   Reply With Quote
Old   January 24, 2013, 08:34
Daniele Vicario
Thanks for your time. Have you tried to check your mesh with:
checkMesh -allGeometry -allTopology
and see how many (and if...) undeterminet cells it has ?
BTW: I use Salome but just to preprocess existing STEP geometry. Then usually I use SHM. I tried several times meshing with it but I found it quite instable (i.e. lots of crash), above all making submesh.
Which version are you using ? Do you download it from the official site ?
Daniele Vicario
Old   January 24, 2013, 10:55
Default Mesh OK
Ilya
Here my checkMesh output:
Checking geometry...
    Overall domain bounding box (-0.05 -0.05 0) (0.05 0.05 0.375)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-8.45579e-18 -2.98649e-18 -1.5611e-17) OK.
    Max cell openness = 2.74985e-16 OK.
    Max aspect ratio = 4.80757 OK.
    Minumum face area = 6.88965e-07. Maximum face area = 0.000152252.  Face area magnitudes OK.
    Min volume = 3.02192e-10. Max volume = 6.23914e-07.  Total volume = 0.00198994.  Cell volumes OK.
    Mesh non-orthogonality Max: 50.6206 average: 15.2056
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.557965 OK.
    Coupled point location match (average 0) OK.
Mesh OK.
Mesh is good. In this case i checked mesh with refinement. I think the problem in your mesher. However SALOME uses NETGEN algorythm. May be you did something wrong in NETGEN settings.
Yes, It could be unstable due to big mesh and unsufficient memory. So i just restart it and save my projects before each operation with mesh.
I use version 6.4 32-bit from official website.
Old   January 24, 2013, 12:34
Daniele Vicario
Can you please execute checkMesh with -allGeometry -allTopology options ?
PS. I really hope you had find a good way to avoid these cells...
Thanks.
Daniele Vicario
Old   January 25, 2013, 09:19
Ilya
OK!
I executed it with options -allGeometry -allTopology and got an undetermined cells as you describe.
It was pretty strange so i did checkMesh with the same options but on my nozzle head case. The mesh was also generated using SALOME.
So i got same cells in the similar positions as in your case.
There is:
So i think you need keep it simple) it's not your fault
[snappyHexMesh] Snappy creates strange cells far away from boundary vainilreb OpenFOAM Meshing & Mesh Conversion 3 December 16, 2020 05:11
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell Arman_N OpenFOAM Meshing & Mesh Conversion 1 May 20, 2019 17:16
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[ICEM] ICEM prism layer results in Fluent NULL pointer cells Will Anderson ANSYS Meshing & Geometry 5 February 19, 2011 12:17
physical boundary error!! kris Siemens 2 August 3, 2005 00:32
