[mesh manipulation] extrudeMesh and stitchMesh in one step ?
Old   February 7, 2013, 16:44
Default extrudeMesh and stitchMesh in one step ?
Hiroshiman is on a distinguished road
Hi !
I'm working on a pipe-like geometry and I need to extrude the inlet and outlet for the calculation stability.
I'm wondering what is the most efficient method ; the only (no direct at all) one I found yet is to extrude the geometry, use the mergeMeshes to merge the extruded volume to the original one and then stitch the common patches.
Are there any more direct and simple methods ?
Regards,
Florian
Hiroshiman is offline   Reply With Quote
[mesh manipulation] extrudeMesh: Wedge extrusion with positive AND negative angle francois OpenFOAM Meshing & Mesh Conversion 3 October 20, 2013 04:37
