[Other] cyclic boundary condition
Like Tree2Likes
  • 2 Post By bscphil
Old   April 11, 2013, 07:36
Default cyclic boundary condition
Amit Jha
amit_100 is on a distinguished road
can any one given some basic insite of cyclic boundary condition?
amit_100 is offline   Reply With Quote
Old   April 18, 2013, 18:28
bscphil's Avatar
Phillip
bscphil is on a distinguished road
Hey Amit,
the cyclic boundary condition is a periodic boundary condition. This is usually use to reduce the mesh size of a rotationally symmetrical domain by cutting-out a piece (e.g for a 360 degree tube, you can only cut a 10 degree piece and set at the cutting planes the cyclic boundary condition).
This is for flows that are in a static sense constant in one direction, then you can set the periodic boundary conditions in these direction (p=zeroGradient @ cyclics, i think ?).
One example is e.g. a axial compressor stage grid... or this http://www.adina.com/newsgH75.shtml
JR22 and mohammad81 like this.
bscphil is offline   Reply With Quote
Old   July 4, 2013, 23:31
Default Cyclic BC for Cavity problem
Mohammad
mohammad81 is on a distinguished road
Hi everyone.
I want to use cyclic (periodic) BC for cavity problem. it sounds simple. I want to use cyclic BC for both P and U (for inlet and outlet). I want to know what I have done is correct or not. Thank you.
This is blockMeshDict:
patches
wall topWall
(3 7 6 2)
wall bottomWall
(1 5 4 0)
cyclic inout
(0 4 7 3)
(2 6 5 1)
empty frontAndBack
(0 3 2 1)
(4 5 6 7)
This is my Boundary file:
4
topWall
type wall;
nFaces 40;
startFace 1540;
bottomWall
type wall;
nFaces 40;
startFace 1580;
inout
type cyclic;
nFaces 40;
startFace 1620;
featureCos 0.9;
frontAndBack
type empty;
nFaces 1600;
startFace 1660;
My 0/U is:
inout
type cyclic;
value uniform (0 0 0);
Finally 0/P is:
inout
type cyclic;
value uniform 0;
Is this correct? I got some result. I get the linear velocity and uniform pressure (Couette Flow). But I am not sure of it.
Is this type of using cyclic correct? what is this "neigbourpathc", "fan" etc..?
Thank you very much.
mohammad81 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 07:38
cyclic patchType with inletOutlet boundary condition mikeP OpenFOAM Running, Solving & CFD 3 August 4, 2021 14:29
createPatch cyclic boundary condition KateEisenhower OpenFOAM Pre-Processing 3 September 4, 2018 14:30
Cyclic Boundary Condition Errors? nyflyer OpenFOAM Running, Solving & CFD 2 April 26, 2016 14:14
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
