[Other] OpenFOAM to Z88 mesh
Old   July 3, 2013, 15:54
Default OpenFOAM to Z88 mesh
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Hello everyone,
I've been experimenting with the open source FEA package Z88 Aurora. I was looking to do some analysis based on the conjugate heat transfer in OpenFOAM. I was curious if anyone has done any work on data interchange between these two programs. I was mainly looking to convert a tet-mesh in OF to a tet-mesh in Z88.
Figured I'd ask before I started on a damn fool idealistic crusade
Thanks everyone!
mturcios777 is offline   Reply With Quote
Old   August 18, 2017, 11:05
Matthew Barrington
mebarrington is on a distinguished road
Hi mturcios777,
I know this post is from long ago, but I am just stating what you intended to start in 2013.
I am also looking to use results from OpenFOAM in Z88. Was the data interchange easy? Should I dive right into this?
Any and all advice is appreciated!
mebarrington is offline   Reply With Quote
Old   August 18, 2017, 12:21
Marco A. Turcios
Hello Matthew,
I did do some work on this but only ever tested it on a single geometry. I believe I did it in general like this:
1) Write out the OpenFOAM pointField interpolation to use as source
2) Map the Openfoam point values to the Z88 Points
If you read the Z88 programming manual, you can find the description for the boundary condition files. Its pretty straightforward.
For step 1 I think I just dumped the pointfield with (x,y,z) coordinates and field values through a purpose built Foam utility, then read that file in steps 2 and output the Z88 file. If I knew more about the interpolation function in finiteVolume, I could probably streamline the process by writing a parser to read in the Z88 mesh, directly map the Foam point field to the Z88 point field, then write out the Z88 boundary condition file.
The documentation is all there for how files are formatted and how to set things appropriately. Its just a tedious process. Thankfully, you do it properly once and it should work for all future case.
[Salome] Script for converting a mesh from Salome-Platform to OpenFOAM nsf OpenFOAM Meshing & Mesh Conversion 86 February 8, 2023 10:30
[Commercial meshers] OpenFoam Mesh to Fluent Mesh in parallel case DominicTNC OpenFOAM Meshing & Mesh Conversion 3 November 22, 2017 09:19
[Salome] Mesh conversion Salome to OpenFOAM VMartinez OpenFOAM Meshing & Mesh Conversion 11 April 21, 2014 02:54
OpenFOAM Foundation releases OpenFOAM 2.2.2 opencfd OpenFOAM Announcements from ESI-OpenCFD 0 October 14, 2013 07:18
