[CAD formats] from .dwg file to openfoam format
Old   July 12, 2013, 16:13
Default from .dwg file to openfoam format
zaynah K.
zaynah04 is on a distinguished road
I have a .dwg file from autocad.
I can not export it to .stl format.. can anybody suggest another method on how may i run it in openfoam ?
Cheers
Zaynah
zaynah04 is offline   Reply With Quote
Old   August 20, 2013, 05:03
Artur's Avatar
Artur
Artur will become famous soon enough
You need to convert your file to a 3D geometry in order to be able to export it to an .stl. Depending on what software you have available, you could use Autodesk Inventor (easiest), Rhino (there is an evaluation version you can download for free, at least there used to be), or perhaps AutoCAD itself if your version has 3d modelling features (I've never used AutoCAD for that so hard for me to say if that's very feasible).
Optionally, you can always export your .dwg as an IGES file and use with any other CAD package to create a 3d model.
Not sure if that answers your question, perhaps try to be a bit more specific about the problems you're having.
Cheers,
A
Artur is offline   Reply With Quote
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 tlcoons OpenFOAM Installation 13 April 20, 2016 17:34
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 towanda OpenFOAM Community Contributions 6 September 5, 2015 21:03
[swak4Foam] build problem swak4Foam OF 2.2.0 mcathela OpenFOAM Community Contributions 14 April 23, 2013 13:59
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
