[blockMesh] Problems meshing a half of a cylinder with blockMesh
Old   November 25, 2013, 10:47
Default Problems meshing a half of a cylinder with blockMesh
Alex
zfaraday will become famous soon enough
Hi FOAMers!
I'm trying to mesh a geometry formed by a half of a cylinder and a cube (the way you can see in the attached file). Although I've done the mesh, as you can see in the pic attached, I have had a little problem and I don't know what to do about that. The thing is that it forces me to divide the blocks 1 and 2 in the same amount of cells in the angular direction that block 0 is. Otherwise I get the following error message:
--> FOAM FATAL ERROR:
Inconsistent number of faces between block pair 0 and 2
    From function blockMesh::calcMergeInfo()
    in file blockMesh/blockMeshMerge.C at line 221.
I would like to divide the cylinder uniformly in the radial direction, so I need to solve that issue.
Another curious fact I have found is that the internal faces between blocks 0 and 1, 2 and betwen block 3 and 1,2 are considered as default faces (empty) after executing blockMesh (as you can see in the attached pic). I don't know if it can cause some trouble when computing with laplacianFoam or not. If so, I would like to know how to solve that. This is my blockMeshDict file:
|  \\    /   O peration     | Version:  2.2.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
       Mapa conceptual
              ·2/11
       3/12.  .8 \
          /7. |17 \
         / 16 |    \
     4\13·____.____·1/10
         |    |0/9
     5/14.____.6/15
convertToMeters 0.001;
vertices
  (0   0    0)                        //vertice 0
  (30  0    0)                        // 1
  (0   30   0)                        // 2
  (-21.213203436 21.213203436    0)   // 3
  (-30 0    0)                        // 4
  (-30 -10  0)                        // 5
  (0   -10  0)                        // 6
  (-14.142135624  14.142135624   0)   // 7
  (0 20 0)                            // 8
  (0   0    10)                       //vertice 9 -> 0'
  (30  0    10)                       // 10 -> 1'
  (0   30   10)                       // 11 -> 2'
  (-21.213203436 21.213203436    10)  // 12 -> 3'
  (-30 0    10)                       // 13 -> 4'
  (-30 -10  10)                       // 14 -> 5'
  (0   -10  10)                       // 15 -> 6'
  (-14.142135624  14.142135624   10)  // 16 -> 7'
  (0 20 10)                           // 17 -> 8'
blocks
    hex (0 0 1 2 9 9 10 11) base (4 3 1) simpleGrading (1 1 1)      // bloc 0, 1/2 de peça
    hex (2 3 7 8 11 12 16 17) generacio (4 1 1) simpleGrading (1 1 1)     // bloc 1, generació
    hex (0 0 8 7 9 9 17 16) base (4 2 1) simpleGrading (1 1 1)       // bloc 2, sota del generació
    hex (0 0 3 4 9 9 12 13) base (2 3 1) simpleGrading (1 1 1)       // bloc 3, 1/8 cilindre esquerra
    hex (0 4 5 6 9 13 14 15) base (3 4 1) simpleGrading (1 1 1)      // bloc 4, rectangle
edges
   arc 1 2 (-30 0 0)
   arc 2 3 (-30 0 0)
   arc 3 4 (0 -30 0)
   arc 8 7 (-20 0 0)
   arc 10 11 (-30 0 10)
   arc 11 12 (-30 0 10)
   arc 12 13 (0 -30 10)
   arc 16 17 (20 0 10)
boundary
    blocMetalic
        type patch;
        faces
            (1 10 11 2)
    aillant
        type patch;
        faces
            (1 0 9 10)
	    (0 6 15 9)
    aigua
        type patch;
        faces
            (3 2 11 12)
	    (4 3 12 13)
	    (5 4 13 14)
	    (6 5 14 15)
mergePatchPairs
Besides, when I apply splitMeshRegions to create the regions directories it creates 2 more regions, these are domain0 and domain2. I don't know if this is related with the previous issue I mentioned before...
Thanks in advance!
Web site where I present my Master's Thesis: foamingtime.wordpress.com
The case I talk about in this site was solved with chtMultiRegionSimpleFoam solver and involves radiation. Some basic tutorials are also resolved step by step in the web. If you are interested in these matters, you are invited to come in!
Last edited by zfaraday; November 25, 2013 at 15:04. Reason: changed what is painted in red (radial to angular)
zfaraday is offline   Reply With Quote
Old   November 26, 2013, 08:33
Alex
Well, I've been trying other ways to define that mesh and I finally found the way you can see in the attached picture and in the blockMeshDict file pasted here:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
       Mapa conceptual
              .7/9
           / 2·5 \
     10/15.  /|\  \
        /  /11/16\  \
12/17.__.___20.21___.__.6/8
     |  0/3   |     1/4
     .________.
   13/18     14/19
vertices
  (-20   0    0)                        //vertice 0
  ( 20   0    0)                        // 1
  (0    20    0)                        // 2
  (-20   0   10)                        //vertice 3
  ( 20   0   10)                        // 4
  (0    20   10)                        // 5
  (30    0    0)                        // 6
  (0    30    0)                        // 7
  (30    0   10)                        // 8
  (0    30   10)                        // 9
  (-21.213203436 21.213203436    0)     // 10
  (-14.142135624  14.142135624   0)     // 11
  (-30   0    0)                        // 12
  (-30 -10    0)                        // 13
  (0   -10    0)                        // 14
  (-21.213203436 21.213203436   10)     // 15
  (-30   0   10)                        // 17
  (-30 -10   10)                        // 18
  (0   -10   10)                        // 19
  (0     0    0)                        // 20
  (0     0   10)                        // 21
blocks
    hex (20 20 1 2 21 21 4 5) (12 6 1) simpleGrading (1 1 1)
    hex (20 20 2 0 21 21 5 3) (12 6 1) simpleGrading (1 1 1)
    hex (2 1 6 7 5 4 8 9) (12 3 1) simpleGrading (1 1 1)
    hex (11 2 7 10 16 5 9 15) (6 3 1) simpleGrading (1 1 1)
    hex (0 11 10 12 3 16 15 17) (6 3 1) simpleGrading (1 1 1)
    hex (13 14 20 12 18 19 21 17) (9 5 1) simpleGrading (1 1 1)
edges
   arc 1 2 (-20 0 0)
   arc 2 11 (-20 0 0)
   arc 11 0 (0 -20 0)
   arc 6 7 (-30 0 0)
   arc 7 10 (-30 0 0)
   arc 10 12 (0 -30 0)
   arc 4 5 (-20 0 10)
   arc 5 16 (-20 0 10)
   arc 16 3 (0 -20 10)
   arc 8 9 (-30 0 10)
   arc 9 15 (-30 0 10)
   arc 15 17 (0 -30 10)
   arc 2 0 (0 -20 0)
   arc 5 3 (0 -20 10)
boundary
    blocMetalic
        type patch;
        faces
            (6 7 9 8)
    aillant
        type patch;
        faces
            (1 6 8 4)
	    (20 1 4 21)
            (14 20 21 19)
    aigua
        type patch;
        faces
            (7 10 15 9)
            (10 12 17 15)
            (12 13 18 17)
            (13 14 19 18)
mergePatchPairs
Meshing in this way I finally got the mesh structure I was looking for but now I noticed that other internal faces are auto defined as default faces by OpenFOAM when I apply blockMesh. These are the ones shown in the attached pic.
The issue mentioned above I found out that it isolates the blocks that the faces belong to when applying laplacianFoam, as it can be seen in the other attached pic. Therefore I need to get rid of those default faces auto defined when I apply blockMesh.
I would be really grateful if someone could give me any advice to solve that problem, because I've been trying many tricks the latest days but I still haven't found out the proper way to solve it.
Regards.
Old   December 11, 2013, 03:41
Thangam Natarajan
Thangam is on a distinguished road
default faces usually arise if you have not defined those faces in your boundary definition (in the blockMesh file). In your blockmesh file, you have not defined the top and bottom surfaces and some surfaces within the geometry. I guess you have include these surfaces in the boundary section of your blockMesh file and define them according to your physical problem suitably as patches or walls.I think once you have defined all the surfaces in the geometry and got rid of the default faces, you should be able to process it.
Hope this helps.
Thangam is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
[ICEM] Simple pipe meshing - problems with y+ in CFX Keizers ANSYS Meshing & Geometry 23 January 15, 2015 08:00
[ICEM] Problems with meshing a 3D wing w/winglet cesarcg ANSYS Meshing & Geometry 10 March 18, 2013 12:12
[blockMesh] Specifying boundary faces failes in blockMesh blaise OpenFOAM Meshing & Mesh Conversion 0 May 10, 2010 03:56
ICEM CFD Meshing Problems: Hexa Dominant Evan CFX 6 July 3, 2006 12:37
