January 5, 2014, 05:44 |
Double Wedge Mesh
Ashwani
Rep Power: 12 |
Hi all,
I am quite new to OpenFoam. I am trying to extend the 15dwedge problem given in the tutorial of rhoCentralFoam or DMSC Foam to 15d double wedge problem. I have modified the existing blockMeshdict file. It is attached below. I am getting error. Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM Warning : From function polyMesh:: polyMesh(... construct from shapes...) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 888 Found 8 undefined faces in mesh; adding to default patch. Check topology Basic statistics Number of internal faces : 3 Number of boundary faces : 18 Number of defined boundary faces : 18 Number of undefined boundary faces : 0 Checking patch -> block consistency Creating block offsets Creating merge list --> FOAM FATAL ERROR: Inconsistent number of faces between block pair 0 and 3 From function blockMesh::calcMergeInfo() in file blockMesh/blockMeshMerge.C at line 221. FOAM exiting Please anyone can help. It is almost 1st problem I am trying apart from the tutorial ones. |
January 9, 2014, 10:08 |
#2 | |
Nima Samkhaniani
Rep Power: 24 |
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
[Other] Wedge patch '*' is not planar | LilumDaru | OpenFOAM Meshing & Mesh Conversion | 6 | January 12, 2021 05:55 |
CFD by anderson, chp 10.... supersonic flow over flat plate | varunjain89 | Main CFD Forum | 18 | May 11, 2018 07:31 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
Fluid-Structure-Interaction on wedge mesh | WiWo | OpenFOAM | 6 | March 6, 2010 07:18 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
