[Other] ideasUnvToFoam for flow past cylinder
Old   October 3, 2014, 06:33
Default ideasUnvToFoam for flow past cylinder
rafath
R_21 is on a distinguished road
Hi all,
I am new to openfoam. I used Salome to generate geometry for flow past cylinder and when converting in OpenFOAM the following error occurred. Please Help..
Create time
Processing tag:2411
Starting reading points at line 3.
Read 31080 points.
Processing tag:2412
Starting reading cells at line 62166.
First occurrence of element type 11 for cell 1 at line 62167
First occurrence of element type 44 for cell 165 at line 62659
First occurrence of element type 115 for cell 2089 at line 66671
Read 14000 cells and 31040 boundary faces.
Processing tag:2467
Starting reading patches at line 165929.
For group 1 named right trying to read 14400 patch face indices.
For group 2 named left trying to read 14400 patch face indices.
For group 3 named Cylinder trying to read 160 patch face indices.
For group 4 named Top trying to read 160 patch face indices.
For group 5 named inlet trying to read 80 patch face indices.
For group 6 named bottom trying to read 160 patch face indices.
For group 7 named outlet trying to read 80 patch face indices.
Sorting boundary faces according to group (patch)
0: right is faceZone
1: left is faceZone
2: Cylinder is faceZone
3: Top is patch
4: inlet is patch
5: bottom is patch
6: outlet is patch
Constructing mesh with non-default patches of size:
Top 160
inlet 80
bottom 160
outlet 80
--> FOAM Warning :
From function polyMesh:olyMesh(... construct from shapes...)
in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 626
Found 29680 undefined faces in mesh; adding to default patch.
Adding cell and face zones
Face Zone Cylinder 160
ideasUnvToFoam: ideasUnvToFoam.C:1271: int main(int, char**): Assertion `noveau > -1' failed.
Aborted (core dumped) "
R_21 is offline   Reply With Quote
Flow past a 2D cylinder - High Re (1E+05) - Cd too high Pervispasco OpenFOAM Running, Solving & CFD 4 March 14, 2022 02:19
Drag force coefficient too low for a flow past cylinder at Re= 1e05 Scabbard STAR-CCM+ 2 June 5, 2020 14:44
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low Scabbard Main CFD Forum 21 June 19, 2018 13:58
Drag force coefficient too high for a flow past a cylinder using komega sst Scabbard OpenFOAM Running, Solving & CFD 37 March 21, 2016 16:16
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 13:00
