[Other] How to create a mesh with boundary layers and y+ < 1 |
March 31, 2014, 10:28 |
Rep Power: 12 |
Hi Foamers,
I have been tirelessly trying out different permutation and combination of layer control parameters, so that I can get proper boundary layers and y+ < 1, but to no good effect, when I increase nSurfaceLayers to 10, no layers are added at all, I have a complex geometry, which rotates. Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object snappyHexMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Which of the steps to run castellatedMesh true; snap true; addLayers true; geometry { ImperialBlade.stl { type triSurfaceMesh; } outerCylinder.stl { type triSurfaceMesh; name outerCylinder; regions { ascii { name outerCylinder; } } } }; // Settings for the castellatedMesh generation. castellatedMeshControls { // Refinement parameters maxLocalCells 2000000; maxGlobalCells 3000000; minRefinementCells 0; maxLoadUnbalance 0.10; nCellsBetweenLevels 3; features ( { file "ImperialBlade.eMesh"; level 5; } { file "outerCylinder.eMesh"; level 0; } ); refinementSurfaces { ImperialBlade.stl { level (5 5); } outerCylinder { level (0 0); } } // Resolve sharp angles resolveFeatureAngle 30; // Region-wise refinement // ~~~~~~~~~~~~~~~~~~~~~~ // Specifies refinement level for cells in relation to a surface. One of // three modes // - distance. 'levels' specifies per distance to the surface the // wanted refinement level. The distances need to be specified in // descending order. // - inside. 'levels' is only one entry and only the level is used. All // cells inside the surface get refined up to the level. The surface // needs to be closed for this to be possible. // - outside. Same but cells outside. refinementRegions { outerCylinder { mode inside; levels ((1E15 0)); } } // Mesh selection // ~~~~~~~~~~~~~~ // NOTE: This point should never be on a face, always inside a cell, even // after refinement. locationInMesh (-677.989649107597 -873.503400652118 1357.52027014113); allowFreeStandingZoneFaces true; } // Settings for the snapping. snapControls { nSmoothPatch 3; tolerance 4.0; // 1.0; //- Number of mesh displacement relaxation iterations. nSolveIter 300; nRelaxIter 5; nFeatureSnapIter 30; } // Settings for the layer addition. addLayersControls { // Are the thickness parameters below relative to the undistorted // size of the refined cell outside layer (true) or absolute sizes (false). relativeSizes false; // Per final patch (so not geometry!) the layer information layers { "ImperialBlade.*" { nSurfaceLayers 10; } } // Expansion factor for layer mesh expansionRatio 1.2; finalLayerThickness 0.1; minThickness 0.01; nGrow 0; // Advanced settings // When not to extrude surface. 0 is flat surface, 90 is when two faces // are perpendicular featureAngle 30; // Maximum number of snapping relaxation iterations. Should stop // before upon reaching a correct mesh. nRelaxIter 5; // Number of smoothing iterations of surface normals nSmoothSurfaceNormals 1; // Number of smoothing iterations of interior mesh movement direction nSmoothNormals 3; // Smooth layer thickness over surface patches nSmoothThickness 0; // Stop layer growth on highly warped cells maxFaceThicknessRatio 0.6; // Reduce layer growth where ratio thickness to medial // distance is large maxThicknessToMedialRatio 0.3; // Angle used to pick up medial axis points // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x. minMedianAxisAngle 90; // Create buffer region for new layer terminations nBufferCellsNoExtrude 0; nLayerIter 40; } // Generic mesh quality settings. At any undoable phase these determine // where to undo. meshQualityControls { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 65; //- Max skewness allowed. Set to <0 to disable. maxBoundarySkewness 20; maxInternalSkewness 4; //- Max concaveness allowed. Is angle (in degrees) below which concavity // is allowed. 0 is straight face, <0 would be convex face. // Set to 180 to disable. maxConcave 80; //- Minimum pyramid volume. Is absolute volume of cell pyramid. // Set to a sensible fraction of the smallest cell volume expected. // Set to very negative number (e.g. -1E30) to disable. minVol 1e-13; minTetQuality -1; // 1e-30; //- Minimum face area. Set to <0 to disable. minArea -1; //- Minimum face twist. Set to <-1 to disable. dot product of face normal //- and face centre triangles normal minTwist 0.01; //- minimum normalised cell determinant //- 1 = hex, <= 0 = folded or flattened illegal cell minDeterminant 0.001; //- minFaceWeight (0 -> 0.5) minFaceWeight 0.05; //- minVolRatio (0 -> 1) minVolRatio 0.01; //must be >0 for Fluent compatibility minTriangleTwist -1; // Advanced //- Number of error distribution iterations nSmoothScale 4; //- amount to scale back displacement at error points errorReduction 0.75; // Optional : some meshing phases allow usage of relaxed rules. // See e.g. addLayersControls::nRelaxedIter. relaxed { //- Maximum non-orthogonality allowed. Set to 180 to disable. maxNonOrtho 75; } } // Advanced // Flags for optional output // 0 : only write final meshes // 1 : write intermediate meshes // 2 : write volScalarField with cellLevel for postprocessing // 4 : write current intersections as .obj files debug 0; // Merge tolerance. Is fraction of overall bounding box of initial mesh. // Note: the write tolerance needs to be higher than this. mergeTolerance 1e-6; my blade thickness is 1.25 mm and I am using boundary layer displacement thickness to be 2 times of that, that means final layer thickness of 1 and contracting down to, 1.5e-5 m (desired distance from the blade surface) why is it so hard to get correct y+ and wall distance from the blade in snappy-Hex, I mean is there a tool which could tell average, this is just frustrating. |
April 1, 2014, 06:57 |
stephane sanchi
Rep Power: 18 |
To begin try to add only 1 cell. And check that the mesh is OK. Then only add more cells in the boundary layer.
Stéphane. |
April 1, 2014, 12:19 |
Rep Power: 12 |
mesh, openfoam-2.2.x, wall distance, yplus |
y+ = 1 boundary layer mesh with snappyHexMesh | Arzed23 | OpenFOAM Running, Solving & CFD | 6 | November 23, 2022 15:15 |
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] Help with Snappy: no layers growing | GianF | OpenFOAM Meshing & Mesh Conversion | 2 | September 23, 2020 08:26 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer | seal2013 | ANSYS Meshing & Geometry | 3 | October 6, 2013 16:09 |
