May 22, 2014, 08:47 |
mergeMeshes extended 3.0
Jiri
Rep Power: 13 |
Hi, I have OF extended 3.0, I wish to merge two meshes (rotor and stator) into one. However command mergeMeshes seems to be different than in OF 2.3.0. In 3.0 it requires 4 arguments. I have folder with rotor case and with rotor case. Can anyone tell me how to use this command? Of course I used help thas says
Usage: mergeMeshes <master root> <master case> <root to add> <case to add> [-masterRegion name] [-addRegion name] [-case dir] [-noFunctionObjects] [-help] [-doc] [-srcDoc] but I dont know what is master root and what is master case etc... |
September 24, 2014, 11:39 |
Matthias Stammen
Rep Power: 15 |
Hi Jiricbeng,
although it's some time ago... I faced the same problem today and the following command was working: mergeMeshes . masterCase . slaveCase So, compared to OF-2.3.0 you can add these dots and it's working again :-) Good luck! Matthias |
Turbulence Viscosity Ratio issue in EXtended domain with Pressure Far Field BCs | Muneeb | FLUENT | 0 | December 6, 2018 15:48 |
[Other] Sig Turbomachinery Library OpenFoamTurbo on extended 3.0 version | qjh888 | OpenFOAM Community Contributions | 0 | April 12, 2016 20:47 |
Rotation in extended version 3.0 | filjas | OpenFOAM Programming & Development | 2 | November 5, 2014 12:54 |
[mesh manipulation] MergeMeshes | hsieh | OpenFOAM Meshing & Mesh Conversion | 3 | September 10, 2014 09:15 |
problem in running icoFoam | Alucard | OpenFOAM | 2 | March 17, 2012 09:01 |
