[Other] How to to Check a mesh made with griden |
August 19, 2014, 05:04 |
Rep Power: 11 |
Hey guys,
right know I want to check my mesh wish I made with Gridgen and afterwards transformed it into a FLUENT file. Afterwarts I made the mesh ready for Openfoam with the command: fluentMeshToFoam <meshFile> I tried to tip in checkMesh -meshQuality The answer is: lklug@ulysses:~/OpenFOAM/Wabe/laminarI/constant/polyMesh$ checkMesh -meshQuality /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.0-f5222ca19ce6 Exec : checkMesh -meshQuality Date : Aug 19 2014 Time : 10:59:07 Host : "ulysses" PID : 23388 Case : /home/lklug/OpenFOAM/Wabe/laminarI/constant/polyMesh nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time --> FOAM FATAL IO ERROR: cannot find file file: /home/lklug/OpenFOAM/Wabe/laminarI/constant/polyMesh/system/controlDict at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting Which file does he not find? The FLUENT file is 100% available at that place. the Openfoam mesh also. Could you please help me? thanks! |
August 19, 2014, 05:52 |
Rep Power: 11 |
generally, how do I check I mesh which is made by gridgen and transformed to FLUENT. is it possible to use the "Chech mesh" function?
regards |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Mesh check failed | subhas.hunasikatti@gmail. | FLUENT | 0 | January 19, 2014 04:09 |
critical error during installation of openfoam | Fabio88 | OpenFOAM Installation | 21 | June 2, 2010 03:01 |
problem when converting mesh (made by ICEM) using fluentMeshToFoam | Forrest_Lei | OpenFOAM | 11 | October 16, 2009 06:28 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 18:10 |
