March 22, 2015, 07:16 |
chechMesh error
Sinasi Bahceci
Rep Power: 11 |
I have created a geometry in blockMeshDict, but when I enter checkMesh, I get following error: Wedge patch 'back' is not planar. At local face at (-0.000126865 0.148202 0.0145967) the normal (-2.41311e-17 -0.0980169 0.995185) differs from the average normal (-1.05634e-19 -0.0980172 0.995185) by 1.21686e-13 Either correct the patch or split it into planar parts #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam:olyMesh::calcDirections() const at ??:? #4 Foam:olyMesh:olyMesh(Foam::IOobject const&) at ??:? #5 at ??:? #6 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #7 at ??:? Gleitkomma-Ausnahme Can you please help me? Thanks in regard. My blockMeshDict is attached: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.3; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.01; H 50; h -10; h2 #calc "$h/2"; hM 30; h3 -7.5; r1 0.18; // Radius Jet r2 2.5; // Radius bluff-body r3 15; // Radius coflow r4 #calc "($r2+$r3)/2"; r5 #calc "($r1+$r2)/2"; alpha1 5.625; alpha #calc "$alpha1*3.14159265358979323846/180"; c1 #calc "$r1*cos($alpha)"; //0.17913325 c2 #calc "$r2*cos($alpha)"; //2.487961817 c3 #calc "$r3*cos($alpha)"; //14.9277709 c4 #calc "$r4*cos($alpha)"; //8.707866358 c5 #calc "$r5*cos($alpha)"; //1.333547534 s1 #calc "$r1*sin($alpha)"; //0.017643085 s2 #calc "$r2*sin($alpha)"; //0.24504285 s3 #calc "$r3*sin($alpha)"; //1.470257105 s4 #calc "$r4*sin($alpha)"; //0.857649977 s5 #calc "$r5*sin($alpha)"; //0.131342968 s1m #calc "-1*$r1*sin($alpha)"; s2m #calc "-1*$r2*sin($alpha)"; s3m #calc "-1*$r3*sin($alpha)"; s4m #calc "-1*$r4*sin($alpha)"; s5m #calc "-1*$r5*sin($alpha)"; vertices ( (0 0 0) //0 ($H 0 0) //1 ($H $c1 $s1m) //2 ($H $c2 $s2m) //3 ($H $c3 $s3m) //4 (0 $c3 $s3m) //5 (0 $c2 $s2m) //6 (0 $c1 $s1m) //7 ($H $c1 $s1) //8 ($H $c2 $s2) //9 ($H $c3 $s3) //10 (0 $c3 $s3) //11 (0 $c2 $s2) //12 (0 $c1 $s1) //13 ($h $c2 $s2m) //14 ($h $c3 $s3m) //15 ($h $c3 $s3) //16 ($h $c2 $s2) //17 ($h $c4 $s4m) //18 ($h $c4 $s4) //19 ($H $c4 $s4m) //20 ($H $c4 $s4) //21 (0 $c4 $s4m) //22 (0 $c4 $s4) //23 ($h2 $c2 $s2m) //24 ($h2 $c2 $s2) ($h2 $c3 $s3) ($h2 $c3 $s3m) ($h2 $c4 $s4m) ($h2 $c4 $s4) (0 $c5 $s5m) (0 $c5 $s5) ($H $c5 $s5) ($H $c5 $s5m) ($hM 0 0) ($hM $c1 $s1m) ($hM $c5 $s5m) ($hM $c2 $s2m) ($hM $c4 $s4m) ($hM $c3 $s3m) ($hM $c1 $s1) ($hM $c5 $s5) ($hM $c2 $s2) ($hM $c4 $s4) ($hM $c3 $s3) ($h3 0 0) ($h3 $c1 $s1m) ($h3 $c1 $s1) ); blocks ( hex (45 0 7 46 45 0 13 47) (80 20 1) simpleGrading (0.1 8 1) //0 hex (0 34 35 7 0 34 40 13) (80 20 1) simpleGrading (1 8 1) //1 hex (34 1 2 35 34 1 8 40) (80 20 1) simpleGrading (0.1 8 1) //2 hex (7 35 36 30 13 40 41 31) (80 25 1) simpleGrading (1 8 1) //3 hex (35 2 33 36 40 8 32 41) (80 25 1) simpleGrading (0.1 8 1) //4 hex (30 36 37 6 31 41 42 12) (80 25 1) simpleGrading (1 0.5 1) //5 hex (36 33 3 37 41 32 9 42) (80 25 1) simpleGrading (0.1 0.5 1) //6 hex (6 37 38 22 12 42 43 23) (80 30 1) simpleGrading (1 8 1) //7 hex (37 3 20 38 42 9 21 43) (80 30 1) simpleGrading (0.1 8 1) //8 hex (22 38 39 5 23 43 44 11) (80 20 1) simpleGrading (1 0.5 1) //9 hex (38 20 4 39 43 21 10 44) (80 20 1) simpleGrading (0.1 0.5 1) //10 hex (14 24 28 18 17 25 29 19) (50 30 1) simpleGrading (10 8 1) //11 hex (18 28 27 15 19 29 26 16) (50 20 1) simpleGrading (10 0.5 1) //12 hex (24 6 22 28 25 12 23 29) (50 30 1) simpleGrading (0.1 8 1) //13 hex (28 22 5 27 29 23 11 26) (50 20 1) simpleGrading (0.1 0.5 1) //14 ); boundary ( AXIS { type empty; faces ( (0 34 34 0) (34 1 1 34) ); } OUTLET { type patch; faces ( (1 2 8 1) (2 33 32 8) (33 3 9 32) (3 20 21 9) (20 4 10 21) ); } COFLOW { type patch; faces ( (14 18 19 17) (18 15 16 19) ); } BLUFF { type wall; faces ( (13 7 30 31) (31 30 6 12) ); } FUEL { type inlet; faces ( (45 46 47 45) ); } WALL { type wall; faces ( (4 39 44 10) (39 5 11 44) (5 27 26 11) (27 15 16 26) ); } BLUFF_WALL { type wall; faces ( (6 24 25 12) (24 14 17 25) ); } JET_WALL { type wall; faces ( (7 46 47 13) ); } front { type wedge; faces ( (45 0 7 46) (0 34 35 7) (34 1 2 35) (7 35 36 30) (35 2 33 36) (30 36 37 6) (36 33 3 37) (6 37 38 22) (37 3 20 38) (22 38 39 5) (38 20 4 39) (14 24 28 18) (24 6 22 28) (18 28 27 15) (28 22 5 27) ); } back { type wedge; faces ( (45 0 13 47) (0 34 40 13) (34 1 8 40) (13 40 41 31) (40 8 32 41) (31 41 42 12) (41 32 9 42) (12 42 43 23) (42 9 21 43) (23 43 44 11) (43 21 10 44) (17 25 29 19) (25 12 23 29) (19 29 26 16) (29 23 11 26) ); } ); mergePatchPairs ( ); // ************************************************** *********************** // |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
