[blockMesh] problem on meshing cylinder on a surface
Old   October 17, 2015, 02:00
Default problem on meshing cylinder on a surface
kuro is on a distinguished road
Hi all, I am new to CFD. I am having troubles to create a mesh using blockMeshDict. I am trying to create a cylinder lying on a surface with a pot hole in the middle.
I just need to create the geometry for now. the dimensions are not need. Can anyone help me on creating the blockmeshdict?
Thank you very much!!
kuro is offline   Reply With Quote
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
[blockMesh] Meshing inside a cylinder so that the edges contain more cells than the center Bertrand OpenFOAM Meshing & Mesh Conversion 1 April 13, 2010 04:46
Meshing problem in GAMBIT Vidya Raja FLUENT 0 May 20, 2006 23:31
POROUS SURFACE MESHING PROBLEM subramani.j Siemens 1 March 3, 2004 04:45
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
