[Other] Import fields to new mesh
Old   December 31, 2015, 11:33
Default Import fields to new mesh
DGW
DGW is on a distinguished road
Hello everyone !
I am currently running a simulation using the rhoCentralFoam solver and everything is going relatively well.
The problem is that there are areas of my mesh I would like to refine by, for example, changing the number of cells of some of the hexaedras of my blockMeshDict, but WITHOUT having to restart my sim from 0 (and lose the dozens of hours of computing time I used). So basically, make a "new" mesh from the same geometry but keep the existing solution solution from the "old" mesh.
Is it possible ? If so, how ?
Thank you for your help!
DGW is offline   Reply With Quote
Old   January 1, 2016, 08:38
Paulo Vatavuk
vatavuk is on a distinguished road
Hi DGW,
You can use the mapFields utility as described in item 2.1.5 of the User Guide.
Happy New Year!
Paulo
vatavuk is offline   Reply With Quote
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 04:24
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
