January 19, 2016, 05:18 |
Trouble with symmetryPlane
Sture Smidt
Rep Power: 13 |
I get the following ERROR: $ decomposePar -force /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ /* Windows port by CFD support (www.cfdsupport.com) [based on Symscape] *\ \*---------------------------------------------------------------------------*/ Build : 2.3.x-819030ed51bd Exec : C:\OpenFOAM\cygwin64\opt\OpenFOAM\OpenFOAM-2.3.x\platforms\cygwin64mingw-w64DPOpt\bin\decomposePar.exe -force Date : Jan 19 2016 Time : 09:45:54 Host : "KITEMILL-SS-PC" PID : 15952 Case : C:/OpenFOAM/cygwin64/home/Sture/OpenFOAM/Sture-2.3.x/run/analyser/testWing01 nProcs : 1 fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Decomposing mesh region0 Create mesh --> FOAM FATAL ERROR: Symmetry plane 'sPlane01' is not planar. At local face at (-1.021393333 0 -5.561200854) the normal (0 1 0) differs from the average normal (-3.57823214e-007 0.9999997524 -9.100501642e-008) by 1.976405015e-013 Either split the patch into planar parts or use the symmetry patch type From function symmetryPlanePolyPatch::n() in file meshes/polyMesh/polyPatches/constraint/symmetryPlane/symmetryPlanePolyPatch.C at line 64. FOAM exiting ************************************************** ****** What can I do? Are there any ways to set the geometrical tolerance? Regards Sture |
February 19, 2016, 00:23 |
Rep Power: 15 |
I am not sure if this addresses your question, but is there a particular reason you want to use symmetryPlane only? If I remember correctly from the documentation for symmetryPlane, it states a rather stringent requirement in its definition and suggests the "symmetry" BC as a less strict alternative. Have you given symmetry a shot for your problem? Cheers, Antimony |
March 9, 2016, 00:27 |
Thangam Natarajan
Rep Power: 16 |
may be you could try using the preservePatches( ) within the decomposeParDict. I did not test it though!
symmetryPlane boundary conditions | UHGAR | OpenFOAM Running, Solving & CFD | 2 | June 25, 2019 05:33 |
[Other] Override symmetryPlane Boundary condition | gwj_gavin | OpenFOAM Meshing & Mesh Conversion | 0 | December 1, 2014 16:46 |
Divergent temperature in chtMultiRegion(Simple)Foam | akrasemann | OpenFOAM Running, Solving & CFD | 13 | March 24, 2014 02:54 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
SymmetryPlane Boundary Condition | raytracer | OpenFOAM Running, Solving & CFD | 0 | July 11, 2008 17:04 |
