April 7, 2016, 04:14 |
Specifying boundaries
Hi
I am new to OpenFOAM and CFD. I've made a simple, cubic mesh in tetgen that I've succesfully converted using tetgentofoam. However, my question is regarding solid boundaries: Say I want to specify that the walls normal to the x- and y-directions must be solid and walls normal to z periodic. Do I have to specify that when I generate the mesh in tetgen, or can I wait and do that when using tetgentofoam/OpenFOAM? Thanks in advance. |
[ICEM] Can I define periodic boundaries in an unstructured mesh? | Aoki | ANSYS Meshing & Geometry | 11 | September 14, 2018 01:52 |
[mesh manipulation] Problem with using createPatchDict to define cyclic boundaries | kaszt | OpenFOAM Meshing & Mesh Conversion | 0 | April 1, 2016 21:18 |
2D Rotating Detonation Engine Periodic Boundaries | whitet86 | FLUENT | 2 | June 25, 2015 11:04 |
Setting Flow/Pressure Boundaries in Floworks | Eran | FloEFD, FloWorks & FloTHERM | 3 | August 11, 2009 04:23 |
periodic boundaries - flow through a net | PK | FLUENT | 0 | July 12, 2007 11:58 |
