[Other] Looking for Software For Finding Holes |
May 20, 2016, 09:36 |
Rep Power: 10 |
I try to simulate a flow inside a tube. Therefore I use snappyHexMesh (since it's a complex geometry). Snappy expects the geometry to be closed. For higher refinements levels, my geometry does not seem to be closed. Does anyone know how I can find those small holes? I use ANSA for meshing but there is no function for finding leaks in the geometry - as far as I know (there is only filling holes ..., but this is crap. Thanks for recommendations |
May 20, 2016, 10:56 |
Anton Kidess
Rep Power: 29 |
ANSA has a function for leak checks. I have used it for surface wrapping - I'm not sure if there is another way to access it.
*On twitter @akidTwit *Spend as much time formulating your questions as you expect people to spend on their answer. |
Mass flow through arbitrary holes not on a boundary | Chenelle | OpenFOAM Post-Processing | 1 | October 13, 2015 03:46 |
Perforated sheet with hexagonal holes!? | oj.bulmer | OpenFOAM | 0 | April 10, 2013 09:35 |
[GAMBIT] GAMBIT Meshing of Pipe with Holes Perpendiculer to Flow Stream | rocketman1151 | ANSYS Meshing & Geometry | 7 | November 30, 2011 02:39 |
How to set up meshes of sparse and small holes? | leeyee | FLOW-3D | 1 | September 2, 2010 22:50 |
Flow through multiple holes | Matthew Markham | Main CFD Forum | 3 | January 28, 2009 21:47 |
