[snappyHexMesh] Problem with snappyHexMesh
Old   September 8, 2016, 05:17
Default Problem with snappyHexMesh
Francesco
phemt84 is on a distinguished road
Hi everyone,
I'm a new in OF, and i've got some problem to mesh a really simple geometry. I'm trying to simulate the primary break-up of a liquid jet for my PhD thesis. Usualy i use the commercial code CSI converge to perform ICE and break-up simulations, and this is my first approach to an opensource CFD. The geometry consists in a cylinder with 0.2 mm of radius and 0.6 mm height, attached to a box 1x1x2 mm.
I would obtain a full hex cut cell mesh so i can compare with the Converge results.
I tryed to follow many tutorials but i don't know what is wrong.
I attach you the complete case.
Could anyone help me??
Thank you so Much
Francesco
phemt84 is offline   Reply With Quote
[snappyHexMesh] Problem with decomposePar, snappyHexMesh luca1992 OpenFOAM Meshing & Mesh Conversion 12 August 23, 2017 19:06
[snappyHexMesh] snappyHexMesh problem cfdsolver1 OpenFOAM Meshing & Mesh Conversion 0 June 23, 2016 10:09
[snappyHexMesh] Problem handling with subdictionary in SnappyHexMesh Lorenzo92 OpenFOAM Meshing & Mesh Conversion 0 November 21, 2015 13:57
[snappyHexMesh] Problem with snappyhexMesh: modelling a pore chamber and pore throat model Saideep OpenFOAM Meshing & Mesh Conversion 5 May 10, 2015 14:46
[snappyHexMesh] Problem with snappyHexMesh giack OpenFOAM Meshing & Mesh Conversion 2 September 18, 2014 10:03
